Question about Solar Leviton 6651 Decora Programmable Electronic Timer
Looking for the instruction manual for Leviton timer model 6651-I
Forgot how to program the damn unit??
6651 manual online here: http://www.smarthome-products.com/productspecs/DI-000-06651-22C.pdf
Posted on Mar 11, 2010
Programing instructions
you can look here http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=6124H-I&section=44955&minisite=10251 and click the adobe manual for programming instructions.
May 05, 2012 | Leviton 6124H 24 Hour LCD Programmable...
Change program leviton timer
Copy following link to identify Leviton timer and download manual
http://waterheatertimer.org/Leviton-timers-and-manuals.html
May 02, 2012 | Leviton 1000W / 20A 1HP-120V - 6230M-A -...
Need to know how to set the timer on my leviton timer - under the cover it has 10 slide switches; I don't have the manual.
Sounds similar to 6651 timer.
Open following link to identify timer and download manual:
If timer does not show, add a comment with in-ficus photo of timer posted on Flickr for possible help.
Jun 25, 2011 | Garden
Leviton 6651 Decora Programmable Electronic Timer. When turned on all lights flicker. checked all connections and all are fine. Also replaced with regular switch and lights work fine.
There are a lot of problems that can affect timer operation.
Call 1-800-824-3005
We can start guessing at causes, and then you try some things, and add a comment with what you've done so the possibilities are narrowed down.
This could be a wiring problem, timer problem, load capacity problems, circuit problem, possibly a noise interference problem.
I would check load requirements and wiring first.
http://waterheatertimer.org/Leviton-timers.html
1) Load:
Manual says: DO NOT INSTALL TO CONTROL A RECEPTACLE, FLOURESCENT LIGHTING, A MOTOR, OR A TRANSFORMER OPERATED APPLIANCE.
Some recessed lighting can have transformers.
Try timer in another room on a different load.
2) For single-pole operation, the black and blue wires are used, and yellow wire is capped off.
Try reversing blue and black wires.
Make sure yellow wire is capped off.
3) For 3-way operation, the timer replace one of the 3-way switches.
The other 3-way switch remains in the circuit, but wiring has to be changed on the remaining 3-way.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 10, 2011 | Solar Leviton 6651 Decora Programmable...
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Need instructions to set my timer. Where can I find these?
If this is not your timer, add a comment.
Also see Leviton timers at:
Leviton 6124 manual
Wiring for 6124 timer:
Add a comment if you need help wiring this timer
Nov 30, 2010 | Leviton 24-Hour LCD Programmable Timer,...
How can I program my Leviton timer model 6651-I?
Leviton 6651 Manual.
http://waterheatertimer.org/pdf/Leviton-6651-manual.pdf
Timer requires a battery which should be replaced each 12 to 18 months.
Timer replaces single-pole or 3-way switch, and does not need a separate neutral wire.
Timer is for incandescent lights only.
500 Watt capacity
Push the door for manual override to reverse program that is in effect.
The 14 hour timing period is represented by 24 dip switches.
Each dip switch is positioned for ON or OFF.
Click the dip switch right or left
Start at the bottom
For example: ON for 3 hours, OFF for 4 hours, ON again for 3 hours:
Click dip switches 1 thru 3 to ON position, 4 thru 7 to OFF position, 8 thru 10 to ON position
ON position is to the right.
OFF position is to the left.
At the end of the 14 hour program, the timer turns lights OFF until the original start time is reached after 24 hours.
Timer will operate like this while in AUTO mode, until function switch is moved from AUTO to MAN or OFF modes.
Function switch is located at very bottom of timer door.
To activate program (on first day), function switch is set to OFF position for 2 seconds, and then move function switch to AUTO mode, and programming cycle begins.
Nov 11, 2010 | Solar Leviton 6651 Decora Programmable...
How do i program the LEVITON Decora Timer Light Switch 10/24hrs.
From this website you can download a free instruction sheet in PDF format...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=6216&section=17138
May 12, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Re-programming
Does it have a reset button.use paper clip and hold in until reset, if no give model number. Please rate. Thanks
Mar 17, 2009 | Solar Leviton 6651 Decora Programmable...
Solar Leviton 6651 Decora Programmable Electronic Timer Logo
618 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
