Question about Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX)
Netopia 2241 Modem losing sync?
Can you help?
    Genius:
  • 1,139 Answers
If your modem is losing sync with ADSL 2 that means that your line has a problem. Try having your DSL provider move you to a new Cable and pair.
Posted on Sep 11, 2007
I need to find a driver/sortware program to get my netopia 3D reach wireless adapter up and running. all i can find are these driver scans that want me to install them and scan my computer to tell me I...
Here's a driver-free, software-free solution.
Turn your cable-modem (or DSL-modem) off.
Turn your Netopia off.
Connect:
Ethernet--port on cable-modem <-- cable --> WAN port on Netopia.
One LAN port on Netopia <-- cable --> network-port on your computer.
Turn the cable-modem on, and wait until its lamps settle-down to a repeating pattern.
Turn the Netopia open, and wait until its lamps settle-down to a repeating pattern.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you see)
Login to the web-server running "inside" the Netopia.
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID of your choice.
Select the 'WPA' level of encryption.
Enter a network-password of your choice.
Click OK
Restart the router (if it did not automatically restart).
Disconnect the Ethernet cable from your computer's network-port.
Click "View Available Wireless Networks".
Click the SSID of your new network.
Click Connect.
Enter the password, when prompted.
Voila! You have a wireless connection to the internet.
Oct 24, 2010 | Netopia 3-D Reach (TER/GUSB-N1)...
Newly reinstalled windows is not recognizing my 2241 Netopia driver via ethernet cable. I believe i just need the driver / software that will allow windows to recognize that i have a modem connected
You can do it manually without the CD.
MAke sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the router
ad the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 11, 2010 | Computers & Internet
Constant d/c
Do you have call waiting and is it turned off? If not turn it off, please.
May 29, 2009 | Netopia (3342) Modem
AT&T Netopia DSL modem not opening ports for web servers
Try to open the required ports of your web server on your router.
Mar 05, 2009 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
I have Netopia 3347-02 but i have a Wireless Error help!!!
As im sure you found out the hard way, you have to swap the netopia out. You must've really snapped your lucky fingers for that one. I do this stuff all the time for a living, and I've never seen a Netopia not function correctly, a new one that is from your ISP anyway. Did you get the netopia from your ISP? or did you buy it on E-Bay, or Amazon.com, a netopia from another ISP wont function properly, but the wireless still should.
Bad modem, just swap it out. Its under warranty, its a new modem, that model number just came out last year. You wont even get charge for it. Its just frustrating when new equipment fails, and unfortuanatly, its becoming more and more common place it seems. Don't even get me started on my new motherboards from ASUS.
If its not a project, its no fun, right?...hehe
spin
Feb 22, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Internet light is red
If you haven't done so already I would turn the netopia router off and back on again at least once. If that doesn't solve the problem it's probably a sync issue with your providers equipment. I'm assuming you're using ATT because of the Netopia router, but generally speaking you should contact your provider and have them run a line test.
They can determine if the line is good or not. If It is all working fine at the time you call ask them to run monitoring on the line for the following 24-48 hours to try and anticipate a reoccurrence. Insist that they call you back regardless at the end of the monitoring term to share their results with you.
Hope this helps.
MO
Hope this helps.
Jul 12, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Speedstream 5360 modem
  1. From the System area, , select Network Settings.
  2. Select Edit Settings.
  3. Select Additional Settings, and then select PPPoE Settings.
    1. Enter the PPPoE information provided by .........on the screens for: .......
    2. User Name ......
    • Password
    • Service Name
    1. Select Done. When prompted, select Test Xbox Live Connection.
    Feb 19, 2008 | Computers & Internet
    Netopia modem
    Go to control panel press on add/remove hardwear and when promted to search for new hardwear press on next.And continue as if installing a new hardwear and you will reenable your USB port.
    Aug 18, 2007 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
    Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX) Logo
    545 people viewed this question
    Top Netopia Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    marty morrison
    marty morrison
    Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
