AOL Hourglass I have a fairly new e-machines desktop running XP, with 256 MB of RAM. I have a serious problem with the performance of AOL version 9, security edition, dialup access. I have tried all the standard remedies- reloading AOL, turning off virus checking, turning off firewall protection (have turned it all back on), running a couple of spyware detectors, etc. Nothing works, and the helpers at AOL are useless- all they do is read from some database, and usually know nothing about computers. Here is the problem- I call it the "hourglass problem". In certain circumstances, the cursor turns to a large hourglass (not the animated small flying windows variety) and the entire system hangs up for at least six minutes. I can't get the task manager to show up, or anything else. Even the clock stops! The only power I have is to shut down the machine, or terminate AOL by mousing the X in the upper right corner. When I bring up the task manager before bringing up the AOL software, thinking that I will catch what causes the hourglass problem, I see no change in the list of tasks. The Task Manager is alive, since I see it update occasionally. I always get the hourglass problem once in every session, in different circumstances. The circumstances of the appearance of the hourglass are: 1) Most commonly, about a minute after I have logged on to AOL, upon the first access of a web page after the initial minute. That is, sometimes I can access a web page without this interference, if I work fast enough. 2) Infrequently, even before I have connected to AOL, after I have brought up the AOL software. This means that I can't even log on! I don't have this problem with any other application- I run many different ones. The machine performs very well, as long as I don't run AOL. Also, many times after I run AOL, even though I have logged out successfully, and the AOL window disappears, I can't run anything at all. My desktop appears OK, but I can't bring up the task manager, IE, Word, or even AOL itself. The clock reports correctly, though. Sometimes, if I wait about ten minutes, I can run applications normally. Sometimes, I have to reboot. Most of the time, this phenomenon doesn't happen.
  • Marvin Walden Sep 11, 2007
    HERE IS A REVISION OF THE ABOVE, GIVING MORE INFO:
    I have a fairly new e-machines desktop running XP, with 256 MB of RAM. I have a serious problem with the performance of AOL version 9.0 Security Edition, Rev 4184.5374, dialup access. I have tried all the standard remedies- reloading AOL, turning off virus checking, turning off firewall protection, running a couple of spyware detectors, etc. Nothing works, and the helpers at AOL are useless- all they do is read from some database, and usually know nothing about computers.
    Here is the problem- I call it the "hourglass problem". In certain circumstances, the cursor turns to a large hourglass (not the animated small flying windows variety) and the entire system hangs up for at least six minutes. I can't get the task manager to show up, or anything else. Even the clock stops! The only power I have is to shut down the machine, or terminate AOL by mousing the X in the upper right corner, which doesn't help anything. When I bring up the task manager before bringing up the AOL software, thinking that I will catch what causes the hourglass problem, I see no change in the list of tasks. The Task Manager is alive, since I see it update occasionally.
    I have disabled firewalls and virus checking. When I invoke the Task Manager before starting AOL, so that I can bring it up when I get an hourglass, Task Manager shows no additional tasks on the event of an hourglass. In fact, Task manager shows nothing that is a problem. Minimum CPU activity- 0:00:04, memory not excessive- 52,956K, page faults minimal- 0, VM Size- 36,796K. Commit charge 238 MB is fine (without anti-virus and firewall).
    So it has to be something in AOL that is causing the problem.
    Will AOL admit to that? Have they ever?
    Novelist:
  • 233 Answers
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors.
Try AOL again.
If AOL is still not working...
Un-install AOL.
Shut down completely for at lest 30 seconds, then restart.
Then do a search for all AOL files and folders with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those found.
Restart then run Registry Mechanic again.
Shutdown restart.
Reinstall AOL.
Posted on Oct 15, 2007
SOURCE:
Can I add a NIC card?
Yes, you have the capability to do so. However, I seriously recommending updating the RAM to the maximum capacity.
RAM Technology : SDRAM Installed RAM: 64 MB Max Supported RAM: 256 MB
Jan 24, 2011 | E-Machines eMonster 600 PC Desktop
We have just purchased 18 wheels of steel bigbcity rigs. The cd installs but we cannot bring up any of the three games nor does it show an icon. The package states it is a pc dvd-rom. We are running...
Is Big City Rigs: Bus Driver by ValuSoft you are refering?
OS: Windows® XP/Vista
Minimum Requirements:
•Pentium® 1.7 GHz or similar processor
•512 MB RAM
•DirectX® Compatible Video Card
•128 MB Video RAM
•DirectX® 9.0c
•2 GB Hard Drive Space
•Mouse
Recommended Requirements:
•Pentium® IV 2 GHz or similar processor
•512 MB RAM
•3D Video Card with at least 256 MB Video RAM
•DirectX® 9.0c
•Mouse
Do your PC hardware specification (Recommened requirement) fit the above requirement needed to run the program?
If so, "Right click the setup and install the program as "Administrator"
Update your Direct X 9, to the latest version.
Hope it helps.
Jul 02, 2010 | Computers & Internet
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
Computer runs slow on some games HELP!!!!
In order to play RollerCoaster Tycoon® 3, you will need a PC running Windows with the following minimum requirements.
Minimum and recommended computer specifications are as follows:
Operating System: Windows® 98/Me/2000/XP (Windows® XP recommended)
Processor: Pentium® III 733 MHz or compatible (Pentium® 4 1.2 GHz or compatible recommended)
Memory: 128 MB RAM; 256 MB for XP (256 MB; 384 MB for XP recommended)
Hard Disk Space: 600 MB free CD-ROM Drive: 4X CD-ROM or faster (8X or faster recommended)
Video: Any ATI Radeon™ or GeForce™ 2 with 32MB or higher; or other video card with 32MB and hardware T&L (ATI Radeon™ 64 MB SDR or GeForce™ 2 Pro or other video card with 64 MB or more memory and hardware T&L recommended)*
Sound: Windows® 98/Me/2000/XP-compatible 16-bit sound card*
DirectX®: DirectX® version 9 (included) or higher
Apr 06, 2010 | Computers & Internet
Sager 8500v laptop wont load xp
It depends on the XP version. You can try loading the basic XP 2002 version.
Regards,
HP
Aug 28, 2009 | E-Machines eMachines Desktop PC
Slow System
Upgrade your system RAM.It will improve your system performance.
Apr 03, 2009 | Dell OptiPlex GX110 PC Desktop
Hunting unlimted 4 does not run
Operating System: Windows® 98/Me/XP
DirectX®: 9
Processor: Pentium® 4 1.4 GHz or faster ( 2.0 GHz recommended)
RAM: 256 MB(512 MB recommended)
Hard Drive Space: 1 GB Free
Drives: 8 X CD-ROM
Cards: 64 MB Graphics Accelerator (128 MB recommended) , sound card with DirectX 9 compliant drivers.
\ Other: Mouse, Keyboard
Hello .
These are listed system requirements to run this game.
If you are lacking either one, you will not able to run the game smoothly.
Jun 29, 2008 | Computers & Internet
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
Using music software
Here is a site that will give you info to most of your questions as far as upgrading your Mac. LowEndMac
more ram and a faster hard drive would improve your machine's performance somewhat.
Mar 26, 2008 | Apple iBook G3 Mac Notebook
System requirement
Windows 98 SE, "Millennium", 2000, XP (XP recommended) Intel Pentium or AMD Athlon 800 MHz or higher (1.5 GHz or higher recommended) 256 MB RAM (512 MB recommended) Direct X-compatible graphics card (ATI Radeon or Nvidia Geforce 2 or higher recommended) Direct X-compatible sound card Mouse CD-ROM drive Optional CD burner for creating Video CDs or SuperVideo CDs Optional DVD burner drive for creating DVDs
Aug 05, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Open Questions:
Computers & Internet Logo
160 people viewed this question
Ekse
Alun Cox
