Question about Ovens
1951 Caloric Ultramatic Broiler Unit Won't Come Out
I have a built-in 1951/52 Ultramatic wall unit which is in pristine condition except for the broiler unit. Apparently, it was rarely used by the previous home owner and when I try to open the drawer to try to use it, the drawer is frozen-up. They even left the original manual for the stove and oven! These instructions state that I should remove the outer broiler door (which I can do with no problem) and to ''release trigger'' and slide unit out. I see no ''trigger'' which they refer to. The picture looks similar to the ''handle'' that one pulls up to release and remove the oven floor, but the only thing in the broiler is a slot-shaped hole. I would like to remove the unit so I can lubricate the runners and actually use the broiler. And it would sure help with lighting the pilot light since the ''button'' is located between the broiler drawer and the oven/broiler wall. What a PAIN! Any help would be greatly appreciated.
Thanks!
cj
5 Suggested Answers
  • 20 Answers
SOURCE: The pilot light on my caloric gas oven lights, but
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
Posted on Nov 26, 2009
SOURCE: I have a caloric heritage series gas stove in
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Posted on Jan 04, 2010
SOURCE: I have a caloric wall oven. Ultramatic model
Hello - I have the same exact problem - how did you solve it? I read to take the burner out and soak/clean it...
Posted on Jan 17, 2010
johnrodgers1
  • 80 Answers
SOURCE: Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Posted on Feb 06, 2010
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Have a Frigidare custom imperial double oven, built in, 60-70's. Bottom oven unit went out sometime ago. now my top broiler unit went out. do they still make those units???
I doubt if they still make that model, but the repair parts should be able to be found and ordered. If you can find the equipment id tag on the unit and write down the model number from it, then you can search for the parts.
Most likely you have either switch problems or the heating element and now the broiler element problems.
Sep 19, 2011 | Ovens
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
Cheryli
Dec 29, 2009 | Ovens
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
The pilot light on my caloric gas oven lights, but the oven burner doesn't light. The oven is old, but only used for 2 months before being put in storage for 13 years. The stove top burners work fine,...
Nov 26, 2009 | Ovens
I have a 31-year old Caloric gas wall oven (Model RWD216) that finally died. I am ready to install a new unit, which means taking out the old Caloric. My question is, how do I unhook the gas line from...
first turn the gas off at the meter/ a oven this old may not have a shut off in the back. then you can remove the oven safely/ the line in back will hook to 1/2in or 3/4 pipe stub. . if you have a shut off in the back turn it off and reconnect new range to it . and if not make shure you put one in .. mm
Nov 22, 2009 | Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Oct 18, 2009 | Ovens
240V wall oven,digital readout and oven light come on but no heat
Bad clock assembly although the clock works the solid state switches internally typically go bad even on brand new ovens,does broil work,the top elements should work?
Jan 21, 2009 | Ovens
Ovens Logo
333 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
