Question about Kinyo GZ-401 Computer Speakers
Bought new Kinyo (GZ-401) 4.1, Only has red and white (RCA) jacks
I got the set from Geeks.com and arrived Saturday. Just now opened them up to find out it says on the box: "Made for PS1,PS2, XBOX, DVD, TV, etc,etc!!!"
I got them as I thought that they were compatible for (PC) but they only have the red and white (RCA) jacks and not the connector that plugs into your built in sound card on your motherboard. I need to know if there is a connector that I can plug into the red and white jacks that is connected to the volume control panel that will plug into my built in sound on my (mobo).
If there is, please provide links to what the connector looks like and links for where to get them.
Thanks,
Joseph!
Go to radio shack and get adapter for audio jack.
Posted on Jul 04, 2009
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
I HAVE A PANASONIC VCR PV-7401. THE BACK HAS ONLY A WHITE AND YELLOW RCA OUTPUT JACKS.I HAVE A RED, YELLOW AND WHITE SET OF RCA PLUGS. DO I NEED AN ADAPTER TO REDUCE RED AND WHITE STEREO PLUGS TO A SINGLE...
NO. Your VCR is not stereo capable (white and red), it is only MONO (white) so only connect the white RCA plug to the white jack. Leave the red cable unconnected.
Jan 14, 2011 | Panasonic PV-7401 VHS VCR
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Will this system work on a ps3
yes just connect the audio pin to the audio jack of ps3...
Dec 28, 2010 | Kinyo GZ-501 5.1 Game Zone Surround Sound...
I dont have the drivers for these speakers,i dont get any sound ,my pc sound is ok,do i need the drivers
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 10, 2010 | Kinyo GZ-401 Computer Speakers
I have a friend whose Emerson Flat Panel LCD television works fine except when you hook up a DVD Player to the television set it only shows the movies in black and white. For some reason I can not get it...
How do hook it up? Are you using composite video (Yellow video cable) from DVD Yellow RCA video out to the TV AV1 composite video Yellow RCA jack and RED and WHITE cables for sound. Or you are using component video hook up using RED, BLUE, and GREEN Video cables and the RED and WHITE cables for sound. Please post back and tell us how you have it set up. You just have to match the color of jacks and plugs, unless there is problem in the TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Emerson EWL3706 37 in. LCD Television
Connections Information Requested
Yellow - Video cable
Red - Audio right channel
White - Audio left channel
From DVD to TV
DVD is output
TV is input
Hope this helps.
Jan 18, 2010 | Sansui VRDVD4000 DVD Player/VCR
Connecting the system
HI there bud..what you will need to do , is go to a PC or electronic store . Ask them for a Audio jack to RCA cable for your 5.1 Channel PC speakers , once bought , COnnect the required speakers , and .done :)
Hope it works.Happy new year ;)
Jan 03, 2010 | Kinyo GZ-501 5.1 Game Zone Surround Sound...
Which one of the cables do I hook up to my television from the speaker system?
Its the RCA type , always coloured red and white if you have the 2 cable type , three cable have an extra yellow one for the video signal.
May 12, 2009 | Kinyo GZ-501 5.1 Game Zone Surround Sound...
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
Kinyo GZ-401 Computer Speakers Logo
146 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
