Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesave died
The microwave was running and just turned off as if the power was cut. We confirmed that the outlet was still hot, so not a power issue. The microwave is completely dead.
Thanks for any assistance. We don't know what to do..
Heather
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dyjd
Posted on Sep 30, 2010
GE Spacemaker (LVM1750) Microwave Oven
If the source voltage, the fuse inside the unit are good someone has to follow the voltage in to see where it stops.
Dec 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I was just using the microwave and it died on me. No power to the unit that I can tell.
Check the circuit breaker. If it's pugged into GFCI type outlet or an outlet that's run from one, make sure the breaker didn't trip there.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge model JES1142SJ06 just cut out. No power. Outlet works. it was working and then shut down
Open garbage can lid, and dispose of GE microwave unit. Then buy a replacement.
Jan 03, 2011 | GE Microwave Ovens
The microwave unexpectedly turns off at random times during cooking. The clock face and everything dies. It is then a random amount of time (5-30) minutes before it comses back. It is not the circuit...
You could try a new plug just in case, next the fuse inside or thermal cut out could be @ fault, could be the cable transformer end as it enters the micro.....
Apr 19, 2010 | GE XL1800 1100 Watts Microwave Oven
My GE profile spacemaker II microwave oven will not turn on. I've tried a difference electrical outlet - no luck. It's a JEM31SF001 thanks
you may have a bad power supply in the microwave.or one of the thermal cut out has gone bad.
the next thing would be a bad control board.
Feb 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacesave microwave oven isn't heating. It is about 6 years old but I only installed it and started using it 4 days ago.
heatman101
jhgj
Nov 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power. outlets is fine. please help. thanx GE Spacemaker® 1.7 Cu. Ft. Over-the-Range Microwave Oven Model # JVM1740DMCC
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Aug 29, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
GE Microwave stops running
Mostly with GE I find this to be bad connections at the fuse holder or a bad fuse due to a bad fuse holder. It will break connection and reset the unit when the connection gets hot and expands and then opens and stops power from getting to the unit.
Aug 14, 2017 | GE Microwave Ovens
GE Spacemaker microwave running, then hummed, then died
the magntron has shorted out , then it blew the fuse inside unless you realy LOVE this microwave you should not put money into it . if its the best thing ever ! , parts should cost around 100.00 + labor . ge microwaves go through magntrons all the time , just poorly made .good luck
Jan 16, 2009 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
102 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
