Question about Vicks V3100 1.2 Gallon Humidifier
Filling humidifier I bought the humidifier from a friend and I got a new filter. How do I fill it with water. Of course there wasn't a manual or instructions with it. thank you
  • Anonymous Dec 07, 2007
    how to clean
  • confused and Nov 27, 2008
    what is the solution for a leaking tank?
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Posted on Feb 12, 2008
Need online instruction manual for hankscraft humidifier model 240
I found this. There are no manuals available on line.
Here we have a used working HANKSCRAFT / GERBER COOL VAPOR HUMIDIFIER Model 240 WITH INSTRUCTION MANUAL and STEAMED CLEANED. This humidifier, by Gerber, has a 1 3/5 Gallon Capacity, and produces cool vapor for up to 18 - 20 hours in low, medium or high settings. The humidifier works great , does not have the directional nozzle included but does come with a copy of the instructions.
http://www.ebay.ca/itm/331790662762
Dec 03, 2016 | Humidifiers
How do I clean this humidifer? I have the sesame street elmo and friends cool mist humidifier and I cannot find the manual for cleaning instructions. thank you
The outside you can clean with warm soapy water. The inside can be flushed with a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank and run the unit until the tank is almost empty. Pour out the remaining solution and fill the tank with more of the Bottled Distilled Water. Operate the unit for 30 minutes and the previous solution should have been flushed out by then. I would recommend using Bottled Distilled Water all the time rather than tap water. As tap water has a lot of minerals in it that can cause calcium scale and clog the unit.
Hope this helped you.
Apr 19, 2011 | Kaz Sesame Street Elmo & Friends...
How do you fill the venta humidifier I don't have
http://www.appliancefactoryparts.com/content/pdfs/123738.pdf
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
Dec 24, 2010 | Venta Airwasher VS 207 3.7 Gallon...
Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Feb 09, 2010 | Vicks Humidifiers
No instruction manual
FILLING THE WATER TANKS
1. Before filling the water tanks, push the POWER switch to the “OFF” position and
unplug unit. Refer to cleaning instructions.
2. Remove water tanks from base, turn each tank upside down and remove tank cap
by turning counterclockwise. Fill tank with clean cold tap water.
Replace the tank cap by turning clockwise. Tighten firmly.
3. Carefully pick up tank, since it will be heavy when full, and slippery if wet.
4. Place water tanks on base. Make sure tanks are properly placed, otherwise, the
humidifier will not work correctly.
Feb 11, 2009 | Slant Fin Cool Mist GF-220 Humidifier
Bonaire BCM-645
To replace the filter, follow the steps below
1. Turn the unit off and disconnect from the electrical outlet.
2. Remove the reservoir from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position
4. Lift the housing straight up and place to the side
5. Unlock the wick holder from the base by turning the
lock knob to the unlocked position
6. Remove the wicks from the wick holder
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into
place.
10.Fill the reservoir and place back into housing.
11.Repeat Operating Instructions It will take about 30 minutes
for the humidifier to reach maximum output. You
can purchase replacement filters (model BWF100 filters)
at your local retailer, by calling 1-800-253-2764, filling
out the accessory card, or by visiting
www.bionaire.com. It is recommended that a
replacement filter is purchased for uninterrupted use.
Here is a link for the manual for your humidifier:
http://www.appliancefactoryparts.com/content/pdfs/117223.pdf
Good Luck.
Apr 24, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
Runs, but no humidity
These things have a "sponge" appearing part that is located below the tank. Be sure to totally soak that part in water before trying to use the unit. I had one of these about 3 years ago, and the same thing happened to me. I believe the "sponge", which is really a filter, actually wicks the water into the section of the humidifier that sends water vapor out of the top. You must completely soak it to "Prime" the system, so to speak. That is what worked for me.
Feb 11, 2008 | Honeywell HCM525 Humidifier
Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Jan 01, 2008 | Honeywell HCM525 Humidifier
Need to clean the filter
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is the link to your manual.
Daily Maintenance
1.
Turn switch to OFF position and unplug the cord from wall outlet.
2. Lift the Water Tank from Base. Carefully remove the Water Tray from the base being
careful not to damage the delicate Wicking Filter. Empty excess water from the Water Tray
without removing the Wicking Filter. Remove the Tank Cap and drain any water from the
Water Tank. Rinse the Water Tank with lukewarm water after each use. Wipe accessible
surfaces of the Water Tank and Water Tray clean with a soft, damp cloth.
3. Do not immerse the Base in water. For storage, wipe dry with a soft, clean cloth. Keep
water away from the Air Outlet.
4. Do not leave water in the Water Tank or Water Tray when unit is not in use as it may
result in the build up of mineral deposits and bacteria that can inhibit the output
efficiency of the humidifier. Please note that if water remains in the Water Tank for more
than a day or two, bacterial growth is possible.
5. Replace Water Tray with Wicking Filter. Then replace the Tank. Humidifier is now ready for
use.
Weekly Maintenance
Removing Scale
1.
Remove the Water Tank and empty any remaining water from the Water Tank.
2. Turn switch to the ON position, either low or high speed, and operate Humidifier until the
Wicking Filter is thoroughly dry.
3. Turn switch to the OFF position and unplug the cord from wall outlet.
4. Remove Wicking Filter from the Water Tray by carefully lifting straight up taking care not to
tear filter.
5. Remove the Water Tray from the Base. Fill Water Tray with undiluted white vinegar. Let
stand for 20 minutes.
6. Dampen soft, clean cloth or sponge with undiluted white vinegar and wipe out Water Tray
to remove scale. Do not use soap, detergents or abrasive cleaners.
7. Rinse the Water Tray thoroughly in clean warm water or put in top shelf of dishwasher to
remove scale and vinegar before disinfecting the Water Tray.
Disinfecting the Water Tray and Tank
1.
Fill tank with 1 teaspoon of household bleach in 1 gallon of water. Let stand twenty (20)
minutes, shaking vigorously every few minutes, drain and rinse with clean water until the
bleach smell is gone. Dry with a clean cloth or paper towel.
2. Wipe the Water Tray with a soft cloth dampened in the bleach and water solution. Rinse
the Water Tray thoroughly or place in dishwasher before proceeding.
3. Wipe all exterior surfaces of the Base with a soft, dry cloth. Do not immerse the Base in
water or use water to clean the base. An electric shock may result or the humidifier may
be damaged.
Hope this helps.
Good Luck.
Dec 01, 2007 | Vicks V3100 1.2 Gallon Humidifier
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Vicks V3100 1.2 Gallon Humidifier Logo
868 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Gil Shultz
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
