Question about HP Compaq 6710b Notebook
HP Compaq 6710b - problem with USBs and other peripherals
I dock and undock several times a day when in the office and ultimately the USB's stop working, the mouse and keyboard that are connected to my docking station also stop working. Occasionally if I go to a conference room to push a presentation on a projector, that also won't work unless I reboot. Also, when doing a "restart" the PC gets hung up and sticks on the blue HP logo screen, never going to Windows login. At that point, need a hard power down and power up to get back to normal. Then it all happens again. HP just sent a guy in on Friday to replace the motherboard but it just crapped out on me again. Any ideas??
Fujitsu not saving monitor settings when docking/undocking.
Unfortunately, these, like most laptops, default to the setting on its own and cannot be saved.
Feb 25, 2014 | Computers & Internet
Upgrade from USB 1.0 to USB 2.0 on a HP 6710b laptop with XP
I'm not convinced on this error, because I used to get the same even though I was 100% sure they were USB 2. Unless the OS or hardware manufacturer were lying.
If this matches your specs, your good. I did see several that differ, but this one is HP.
http://h18000.www1.hp.com/products/quickspecs/12685_div/12685_div.html
Nov 25, 2012 | HP Compaq 6710b Notebook
I dock my Latitude D620 and when I go to type only xxxxxxx's print and all by themselves!
Hardware problem. The x key is stuck or pasted. Take it off, clean with alcohol or better special liquid and put it back.
Jun 13, 2012 | HP Compaq Presario V2000 Notebook
Dell 6420 laptop not recognizing USB ports while on docking station
Hello Jackie.
2 of youre USBs are USB 3. so you need to install the right drivers for USB 3.
Also you should check youre BIOS settings, if there is an option to enable "XHCI" support so enable it. (USB 3 needs this to work ).
regards Gue.
Apr 21, 2017 | Microsoft Computers & Internet
Will not print when docked
I would recommend that you undock the laptop, go into the Printers and Faxes console, and delete the printer. Then, dock the laptop, connect the USB cable to the dock and then re-install the printer through the dock. The USB ports on the laptop are assigned different hardware values than the PCI interface of the dock, and if the laptop is trying to print to a local USB port, it may not find the printer if it's connected through a PCI interface like the dock. That'd be my next move.
Mar 04, 2010 | Dell D/Dock Expansion Station Docking...
When HP 6710b laptop is undocked issues arise unless it's
What OS?
this laptop came with
XP
VISTA
or W7
during its production run.... so... we start there.
up grade to 7, the other 2 have no support,
However, the HP site still has it , while the clock ticks, (the 10 year clock is about to delete support.
so get the software while still there{hint})
see below, ive guessed XP-32b ( worst case)
see this, then see the item, software solutions (21)
then see SOFTPAQ? "HP Softpaq, down load manager"
using the correct OS< get this HP software , install it. then
run it and it will load all the correct drivers to you PC like magic. (HP is best, and this is one prime example of best)
SOFTPAQ,
then play docking?
BSOD means.
XP , full of viruses, as all are now, avoid XP like plague. (OS corruption can BSOD super easy...)
Memory bad, try running it on 1 stick, at at time.
DMM sticks.(aka, RAM)
XP with wrong drivers loaded. BSOD.
same with VISTA it too is DEAD OS, now.
in the same box above. (online)
see that docking station driver?HP USB 2.0 Docking Station Driversystem software Manager Icon
Apr 16, 2017 | HP Compaq 6710b Notebook PCw/ OfficeJet...
BLUETOOTH SOFTWARE FOR YOUR PERIPHERAL DEVICE
i want install my bluetooth peripheral device can yu help me
Sep 28, 2009 | HP Compaq 6710b Notebook
Where is the video in port on compaw 6710b ?
bought honestech VHS to DVD 3.0 has a converter - cables from VHS go in usb out and connects to usb on compaq. Good editing software as well.
Jan 28, 2009 | HP Compaq 6710b Notebook
Acer Docking Station
what type of laptop ad docking station do you have?
May 08, 2008 | Computers & Internet
HP Compaq 6710b Notebook Logo
180 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
