Question about Philips DVP5990 DVD Player
My phillips dvd player (model DVP5990) is not reading disc at all no matter the format. any ideas?
    President:
  • 814 Answers
This could be several problems. You should first try to clean the laser head with a cleaning disc. If this does not work you can try resetting the dvd player to the factory settings. This function is found in the settings section under preferences. Use you remote control to open the settings menu and use the up and down arrows to highlight the preferences section. Press ok to enter the sub-menu. Use the up and down arrows to highlight the default setting.Press ok. You have now reset the dvd player to the factory settings. Press the menu button again to escape the menu. All this information is in the owners manual on page (47). Try a dvd to see if the dvd player is working properly. If not you may have other problems that will require you to open the dvd player up to find the problem. These problems could be a laser lens that is not functioning properly or a problem with the transport that is use to set the dvd up for reading by the laser lens. For these problems it is best to have a qualified technician to troubleshoot the problem.You can call phillips customer support at this telephone number 1-800-744-5477. Tell them the model number of your dvd player and the problem you are having with disc player not reading discs. They will be able to help you get service for the dvd player.I hope this information helps you with your problem.
Posted on Jun 02, 2009
Can't Read Disc
You could try updating the firmware.
Jul 06, 2010 | Philips DVP5990 DVD Player
Tip
How to up grade the software in the Phillips dvd players DVP5990 & DVP5992
Installing the latest software
Philips provides software upgrades to
make sure that this unit is compatible
with the newest formats. To check the
updates, compare the current software
version of this unit with the latest
software version available at the Philips
website.
A Press ç to open the disc tray.
B Press numeric keypad ‘55’ on the
remote control.
C Write down the file name.
D Go to www.philips.com/support to check
the latest software version available for
this unit.
E If the latest software version is higher
than the software version of this unit,
download it and store onto a CD-R.
F Load the CD-R to this unit for upgrade
operation.
Note:
Never unplug or turn off this unit
during the upgrade.
G Once complete, this unit will restart automatically
on Jun 02, 2009 | Philips DVP5990 DVD Player
I downloaded a movie on my computer. I burnt the disc and when I put it in the dvd player it says cannot play disc. I have a sony DVD Player. Any thoughts?
The exact model of DVD player matters. Not all models can play a Computer burned disc.
There are several types of DVD
A factory type DVD in DVD format
A burned movie in MPEG format
a burned disc in DivX format.
Etc.
Try burning the disc with a DVD Creator program, not just 'Burn to DVD'. It's not the same thing.
Mar 19, 2010 | JVC XV-N320 DVD Player
Unable to read mkv and avi video files from usb drive on philips dvp5990 dvd player
what error does it give? mine reads avis fine, as long as theyre within resolution limits. same for windows media format. couldnt get the mkv files to work though. the usb drive has to be formatted fat32, ntfs does not seem to work. burning these files to dvd as a data disc is another option. lets you fit 10+ hours of video on the disc vs your standard 2 or 4 hour max limits.
Jan 27, 2010 | Philips DVP5990 DVD Player
Can't play a burned dvd disc on philips dvp 3120
You might have created a data cd, dvd player normally don't support data cd. If that is not the case then you the file format is not support by your dvd player.
You would have to search for a software to convert the file to the format supported by your dvd player. and write it on the disc again.
Jul 29, 2009 | Philips DVP5990 DVD Player
Picture not on whole screen
have you another disc?
some movies are formatted.try to press set-up button on your dvd remote.choose video or tv types.it shows letter box or LB, pan and scan , and 16/9 for widescreen
May 07, 2009 | Philips DVP5990 DVD Player
I installed a parental control code on my phillips dvp5990 dvd player and forgot the code.how do you reset it?
This information was found on the Phillips USA website http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 in the customer support section for you model dvd player. In the owners manual on page (47). I hope this information helps you with your problem. Select this to set the password for Parental control and Disc
Lock. The default password is ‘136900’.
To change the password:
1) Press OK twice to access the change password menu.
Old Password
New Password
Confirm PWD
OK
2) Use the numeric keypad 0-9 on the remote control to
enter your existing six-digit password at { Old Password }.
Note: When doing this for the first time or if you forget your
existing password, enter ‘136900’.
3) Enter the new six-digit password at { New Password }.
4) Enter the new six-digit password again at { Confirm PWD }.
5) Press OK to confirm and exit
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Can't take off disc lock (DVP5990
THE PASSWORD TO THE PHILIPS DVD DISC LOCK IS 136900 THIS IS THE DEFAULT PASSWORD. ONCE YOU UNLOCKED IT PRESS SETUP BUTTON GO DOWN TO DISC LOCK AND CLICK ON UNLOCK.HOPE THIS WAS HELPFUL. PLEASE RATE
Jul 14, 2008 | Philips DVP5990 DVD Player
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Philips DVP5990 DVD Player Logo
423 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
