Question about Friedrich QuietMaster Electronic SS12J30D Air Conditioner
Both inside and outside units did not come on in cool mode
Both the inside and outside units did not come on. But after disconnecting the thermostat and reconnecting it both units came on and blew cool air. Is this indicative of a major problem or is it possible to reset a thermostat (maybe a power surge tripped it???)
  • 374 Answers
thermostat located on your evaporator is adevice where in if temperature set up is acquired the power source will cut off until on specific time that when small heat absorbed thermostat will activate again or this auto activated.meaning there is a differtianl temperature acquited to run this device.this depent how you set up your temperature setting.the over load protection device located mostly on control panel is one tripping off.this is the device you have to reset in order to run the unit again if malfunction., if short circuited or highr current occured on compressor this device protect your motor to burn it will trip off your unit.several factors you can consider in tripping unit,fan motor not running,dirty evaporator and condenser,loosen wiring connection and faulty wiring.sometimes circuit on panel board are envaded by insect mostly ants they need heat for there egg to hatch, they davastated the circuit.check on this.have a nice day don't forgert to rate me thank's.
Posted on Apr 12, 2009
Does outside unit run when thermostat calls for auxiliary heat ?
do not think so . that unit is usually for cooling .
Apr 03, 2018 | Heating & Cooling
AC unit will not turn on and will not cool down
The first thing you want to check is all your breakers and disconnects. You should have 2 breakers in your breaker panel, one that runs unit inside and one that runs unit outside. Turn both off and then back on to make sure they are not tripped. Next go to your unit inside and you want to look for a breaker on the unit and/or a disconnect somwwhere in the immediate area. If it is a breaker, reset that, If it is a disconnect, you have a lever on it or, it may have a pull out piece your going to want to pull out and inspect to make sure it doesn't look burnt. It should say "on" on it and maybe an arrow but when properly installed, you should be able to read "on" right side up not upside down. Next, you want to go to the unit outside. It should have a disconnect of the same fashion, so check it also. At this point make sure your thermostat in in the "on" or "auto", auto would be the right setting but, does the unit run? If so, is the unit outside running as well. If only the inside unit runs, you either have a bad thermostat or a bad capacitor or wire in the unit outside, it could be other things with the unit outside but, these are common items. If everything runs, and it is still not cool, again, the thermostat could be bad or it may be time for a charge. Make sure you filter is clean as well because limited air flow acn cause the unit to freeze up and not work.
Jun 05, 2011 | White Rodgers Water Heaters
{my thermostat was flashing filter} I replaced filter and now air conditioner wont kick out cold air rth230b
Remove the thermostat wires and reconnect wires after 10 minutes. Then check. --------- yellow wire on thermostat is for cooling.Disconnect the yellow wire bolt remove yellow wire and then see if AC works will yellow wire unplugged..If its works that means the Thermostat is the issue.It has to be replaced. On some newer honeywell thermostats.there is blue wire instead of yellow wire.The connection is same, but blue wire is there instead of yellow wire.In that case disconnect blue wire and then see if AC works with blue wire disconnected. ---------- Check this.This will help.Thanks.Helpmech.
Jun 07, 2011 | Honeywell Heating & Cooling
My outside fan will not run and the inside unit runs constantly. can't push the reset button on unit outside
Your out door unit fan motor not runs due to pressure not build up at Heat mode. If its cool mode only fan runs with compressor when thermostat calls for it.
Without having technical knowledge, don't press any reset button. Hope it's helpful?
Dec 09, 2010 | Ruud Central System Air Conditioner
Goodman AC Unit with Heat Pump - Works great cooling when switched to heat the outside unit does not come on - inside comes on and uses emergency heat? What can I check? I first checked the contactor and...
Because the outdoor unit works in cooling, it sounds as though the contactor and other components outside are working correctly. The problem sounds as though it might be somewhere in your thermostat. Has the thermostat been replaced recently? If so, make sure it was wired correctly. If not, check all of the connections and contact points in your thermostat. In order for your outdoor unit to run, you must have 24vac at your "C" Common and "Y" connections. You must have this in COOL mode. Now it has to be determined why you don't have it in HEAT mode. Definitely a thermostat issue.
Hope this helps and good luck! :-)
Mar 05, 2010 | Goodman CKL60AR60 Air Conditioner
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Installing 1 1/2 ton Weatherking Heatpump and ADP WAK351807P2 air handler 1 /1/2 with 7.5KW back up heat kit. Can't seem to get the thermostat hooked correctly. I understand the Weather King product...
O energizes the reversing valve when the thermostat is set for COOL. B energizes the reversing valve when the thermostat is set for HEAT.
The O/B is usually a orange or black wire.
You can't hurt anything if you choose O or B incorrectly. Hook one of them up and run the unit. If set for COOL and the unit runs cool inside it is correct. If set for COOL and the unit runs warm inside it is not correct.
If the inside temp is opposite from your setting change the wire to the other terminal.
Remember to disconnect power from the air handler when changing thermostat wires.
The defrost control board on the outside unit should be marked correctly for O or B.
Your thermostat may have a slide switch rather than a separate terminal.
Oct 30, 2009 | Weather King 10AJA6001AH Air Conditioner
Friedrich QuietMaster Electronic SS12J30D Air Conditioner Logo
129 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
