AC not working
Our AC doesnt seem to work...it doesnt start also, it made a huge noise and came to a halt. please advise
  • Anonymous Nov 07, 2007
    we are dealer for L.G consumer products. We have sold L.G 1.5 ton 2 A/C to Mrs. Margrata Fernandes, Masalvaddo, Anjuna, Bardez, Goa on 20/08/07. After the installation, the party did not use at all as they are in abroad on 05/11/07, they arrived it is found not working when we tried full day on 06/11/07you toll free No. 1800 - 180 - 9999. Always gets the message dial this nummber and that number, but complaint could not get registerad. It is most urgent that, please attended the complaint today with out fail; contact No 0832 - 2273922 and do the needful
    thanking you
    Agnelo Electronics
  • Anonymous Aug 28, 2008
    unit will not start at all. Worked fine first year, then having this issue second year. Did start a few times, but not anymore. Power is fine, timer works, drained of all water, cleaned filter. Out of ideas.
    Problem Solver:
  • 6 Answers
If you can be a bit more specific by stating model and any codes that maybe showing would be useful in diagnosing the fault.
Posted on Nov 14, 2007
    Novelist:
  • 75 Answers
Hi, If you are renting your home, contact the owner or manager. If this is a window unit it may have a reset button at the plug. You also need to check the main breakers in the breaker panel. If its a split unit, I think you should contact a licensed air-conditioning technician to check it out. Find the REPAIR SERVICE tab on here and find one in your area or check the YELLOW PAGES in your phone book under HEATING AND AIR-CONDITIONING. You might want to talk with a neighbor to find a good air-conditioning technician. Without further information, I cant think of anything else. Hope I have helped you. kstfas
Posted on Sep 11, 2007
SOURCE:
My yaris 2007 car ac stopped working before 2 months slowly , means sometimes work and some times doesnt work , and not at all . before 2 weeks i showed 2 car ac tachnicians both told to change control...
The best I can tell u is that the smell is from a leak at the evaporator or connections. I advise to get another opinion because it sounds like a lot of guesswork. if u get the work done, make sure the work comes with a warrantee! I gave all my customers warrantees for 20 years. That's part of the diagnostic business! Good Luck If u don't get a warrantee ,don't get the diagnosis or work done
Mar 25, 2017 | AC Cars & Trucks
Whirlpool mini split
Peek inside the opening on the front of the inside unit. You should be able to see the blower assembly/fan blades. See if any of them blades are cracked, warped, or debris on them. If seen these minisplits mildew on those blades also, which will cause it to be off balance. If you move the fan to different speeds does the sound change? If its down that since day 1, its probably a defect. Hope this helps!
Mar 13, 2017 | Heating & Cooling
Why ac blowing hot air
start off with the cheap possibilities and make your way threw.
I'd start off with replacing Air Charge temperature sensor, make sure your AC Hose isnt leaking anywhere, if those dont solve it then replace ur AC clutch, last chance would be replacing AC compressor. sometimes the compressor will malfunction randomly. or the AC clutch might malfunction aswell. covering these steps somewhere along the line you will have working AC again! good luck
May 18, 2013 | Volvo V70 Cars & Trucks
Ford windstar 2001 ac on the back not working
You likely have a defective expansion valve, recover the charge from the system and pull off the interior panels to expose the AC evaporator core and the expansion valve.
Sep 10, 2012 | 2003 Ford Windstar
My 1997 bmw 328i ac wont work correctly
there is a lot of ac faults on cars seems sence to open a window if hot why ac in cars just anouther problem to sort out lol
Aug 18, 2012 | Cars & Trucks
Dead laptop
Start simple and try another adapter, I usually advise people when this occurs to take it to a local pc shop where they can do some very quick power tests right on the desk there. Trying another adapter is step one, then a test of the DC jack is step 2 and then on to the rest of the power circuit of the motherboard is more extensive and needs a system teardown.
Sep 11, 2009 | Computers & Internet
My ac only works when i hit a huge bump and never again
I've had a similar problem. For me, the armature had some bad spots... or the bearings were going bad. So, I'd open the hood and tap the motor with a rubber mallet. Then, I'd reach through the open passenger window to feel if the air was coming from the vent. This would work very well until the blower motor finally went completely bad.
Apr 30, 2009 | 2000 Lincoln Town Car
Heating & Cooling Logo
176 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
