Question about Grilling
Cannot get the cadac to light
I was given a cadac easy chef for christmas and have used it less than 6 times. When I tried to light it last week I could not get it to work. I stripped it all down as I could hear the gas and smell it coming through. When I took off all the pipes and the base plate (underneath the legs)I could see a blue piece of plastic in the shape of a funnel in the tube .I did manage to remove this but not sure what its for. I have not tried to light again without this 'bit' just in case it is some sort of safety device.
The blue tube is the air baffle, it should be in there but the people at cadac told me it will work safely without it. this baffle has been known to melt on occasions, i phoned cadac and they sent me out a new one free of charge. dont know why yours wont light though. mine produces a yellow flame instead of a blue flame?
Posted on Jun 24, 2009
Which gas is recomended for use on a cadac eezy chef as mine is generating black smoke on propane
You get black smoke - and other unwanted & unexpected effects -
'cause 'false draft' occurs during mixture process in the venturi pipe,
PREVENTING THE BURNER FROM 'INHALING' ITS SPECIFIED
PERFECT COMBUSTIBLE HIGHLY CALORIC GAS/OXYGEN MIX.
THIS MIXTURE PROCESS CAN BE IMPROVED BY FOLLOWING
THE INSTRUCTION AS OBSERVED IN THE YOUTUBE VIDEO
'THE CADAC LEGEND',
AS PUBLISHED AUGUST 15, 2011.
May 03, 2011 | CADAC Safari Chef Portable Grill
Cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Oct 08, 2009 | CADAC Safari Chef Portable Grill
I need an instruction booklet in order to sell a Cadac Carri Chef
go to there homepage and find files and download it disc usually it s an adobe file and burn from there
Aug 10, 2009 | CADAC Grilling
Cadac eazi chef flame burns yellow and makes a lot of soot.This happened after i tried to light it and there was some kind of blow back and some smoke but no visible flame. I have striped it down as far as...
Yellow flame = not enough air. (Remember using Bunsen burners in school science lab? Air hole closed = yellow flame). Have you twisted the main metal tube (whilst trying to remove the burner assembly)? Remove the gas tube and metal plate (6 small cross headed screws). Draw out the gas valve. Look into the metal tube. You should see 3 slotted holes - the air holes. On mine they had twisted and were blocked by the plastic of the leg assembly. Using a good pair of pipe grips, rotate the metal tube until the air holes are clear. Then re-assemble. My Cadac Eazy Chef now works like new.
Jul 01, 2009 | Grilling
Were do the parts go on the cadac bbq
hi i need a new gas igniter for my carrie chef, can you tell me where i can buy one
Jun 15, 2009 | CADAC Safari Chef Portable Grill
Require instruction manual
http://www.cadac.co.za/index.php?page=usermanuals TRY HERE FOR MANUALS
I have just bought this product and have got the manuals with it!!! They arent clear
May 27, 2009 | CADAC Grilling
Cadac safari chef
Hi Paul
I asked the same question and found this web site which sell a propane regulator.
http://www.flogas.co.uk/buy-online/gas-barbecues/cadac-carri-chef-deluxe-combo-8150/
Cheers
Sepp
Jun 11, 2008 | CADAC Safari Chef Portable Grill
Cadac carri chef
Hi Ronaddo, where are you living?
Jun 01, 2008 | CADAC Grilling
Grilling Logo
352 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
