Question about Quickie Wheelchairs Quickie Aspire Power Wheelchair Cane Crutch Holder
Aspire Quickie Battery Charger
Battery charger is not making the "fan" noise or charging the batteries. We have a green "charging"l ight on the front of the chair and it is working but the charger isn't
  • 32 Answers
Most chargers have an external or internal fuse, try replacing.
Posted on Jul 13, 2009
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
When trying to charge batteries, charger will kick on for a few minutes & then off, on, then off. What is problem?
Unfortunatly, your batteries need to be replaced. The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of power, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own, check your owner's manual or contact the manufacturer for the battery type. Good luck!
Oct 28, 2010 | Quickie Wheelchairs Quickie Aspire Power...
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
The wheelchair will only move when the charger is plugged in. Unplug and all lights are normal but no motor actuation. thank you fo4r your help
berry boy Not alot of information but when you say all lights are normal do you mean the battery level lights are all lit up and there are no flashes. Usually when this happens the battery level is too low to make the chair move. When you have the chair plugged up the charger gives enough power to make it move. If you have a digital voltmeter set it 200 vdc then plug the 2 test leads into the 2 outter charger port holes. You should be able to read the battery level and after a full charge should be reading 25-27 volts. Hope this helps
Sep 19, 2010 | Quickie Wheelchairs Quickie Aspire Power...
How do i charge the battery
Carla Under the front bottom of the joystick you will see a charger port its a three pin port that accepts the plug from the charger. Always plug the charger into this port with the charger off or not plugged into the electircal socket. Then plug the charger into the electical socket or turn it on. You should see a red light and a yellow light on the charger. When the tellow light turns green the batteries are charged. You should get into the habit of charging the batteries each night if you use the chair daily. Just plug in the charger when you go to bed and turn it off when you get up. If you only use the chair a little then always store it fully charged and then charge it once a week if it hasn't been used. Hope this helps you
Sep 12, 2010 | Quickie Wheelchairs Quickie Aspire Power...
My wife has a Quickie V-521 that is full charged however when you disconnect the charger all the lights flash and the reset button is depressed and will notpop back out
Make sure the chair is not in freewheel mode. Also just because the batteries read fully charged does not mean that they are "good" batteries. Have them load tested. As far as the reset button, the normal positon is pushed in.
Oct 10, 2009 | Quickie Wheelchairs Quickie Aspire...
My suns Quickie P320 (dual battery) requires very
Rapid discharge usually is a sign of weak batteries, and they should be replaced if the charge indicates that they are full after charging for several hours, and then dissipate rapidly.
If your not getting a full charge indication after several hours, then you need to check the charger to make sure it is putting out about 28 Volts DC. If it is, then it is for sure the batt's.
The sweeping lights should not occur when the chair is off the charger. They sweep while on charge to tell you that it is charging and you can't move the chair. If they sweep while off the charger, turn off and restart and it should go. If not, call a tech. rep. for Quickie.
Sep 29, 2009 | Quickie Wheelchairs Health & Beauty
My quickie aspire wont turn on
3 months is too long for gel batteries to sit off-charge, without being fully charged first, then disconnected before storage.
Your charger is trying to charge, but the batteries aren't cooperating. This chair accepts either the Group 22 or Group 24 gel-sealed batteries. 22 are about 50 amphour, and 24 are about 74 amphour, and will give you greater range. Cost for a set of two of either is going to be about $350 and $450 respectively. Ouch!
Jul 07, 2009 | Quickie Wheelchairs Quickie Aspire...
Battery charger not charging
Try calling Sunrise @(303) 218-4500
   Will the battery charger even come on?
Mar 19, 2009 | Pfizer Quickie Revolution by Sunrise...
Quickie Wheelchairs Quickie Aspire Power Wheelchair Cane Crutch Holder Logo
392 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
