Question about HP Officejet 7130 All-In-One InkJet Printer
Cartride jam with loud noise
It says cartridge jam makes loud noise
    President:
  • HP Master
  • 990 Answers
Hello sir; un-plug machine, now you move cartridge much easilier, just move for and back ,to find out what's block the way.
Posted on Apr 12, 2009
I have a paper jam, and when I turn it on it is making a loud noise. Can I fix it?
Yes, try to open the door from where you insert cartridge. And try to remove the cartridge.
You should see the paper behind the cartridge loading place. Remove the paper. Make sure it is completely remove. Restart your printer.
Jan 26, 2016 | Office Equipment & Supplies
Canon Pixma MP780 makes a loud clicking noise. No paper jammed anywhere. It seems to be the gears where the cartridges are.
i have th same exact problem, just took much of it apart, bu still cant see why it makes the loud noise, also I cant switch paper feed to back, which at least would allow it to print from there... please let me know if you find a solution.
Nov 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have an epson stylus cx6000, after I put in a new ink cartiage it started making a loud grinding noise an now it won't print.
Sounds like a cartridge jam. Remove the cartridges and look at the carriage path. Make sure there is no paper or anything else in the way.
Sep 10, 2010 | Office Equipment & Supplies
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
How do I fix a cartride jam?
Have you tried
(1) running "print clean" or something like that?. (If you don't know how to do that, check your manual).
(2) Removing cartridge/s and installing again?
(3) Cleaning head by dabbing lightly with Q-tip in isopropyl alcohol?
Other possible solutions depend on answers.
Sep 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Cartridge jam
The clicking noise is usually the clean station plugged with old thick ink. You need to dig your way down to the clean station wash it out completely, and also clean the encoder strip. usually a shop repair.
Jul 13, 2009 | HP OfficeJet 7310 All-In-One InkJet...
1600n grinding and jamming
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Dell 1600n All-In-One Laser Printer
Jammed at far right (error message ##345)
hi
I don't know if you have the same problem as me but my printer kept saying cartridge jammed so I opened it up and moved the cartride head gently to the left and got a flash light there is a little peice of metal on the base where the cartridges sit you have to make sure it is cliked back in and now mine works again.
I hoe this helps
Sep 20, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
HP Officejet 7130 All-In-One InkJet Printer Logo
155 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
