Question about Kenmore Vacuums
I HAVE A KENMORE 34612306 UPRIGHT VACUUM. IT SEEMS TO OVERHEAT AND STOP AFTER USING FOR 20 MINUTES OR SO. ANY POSSIBLE SOLUTIONS??
  • 281 Answers
The filters may be clogged causing the motor to run fast which is causing the motor to get too hot..make sure you don't have any clogs anywhere like your hoses or at the bottom
Posted on Apr 13, 2009
Water spray not functioning for hose or carpet. I purchased this about 3 weeks a go. The spray work for about 20 mins then stopped. Is there are reset? I have tried turing off and on etc. Wendy...
Wendy,
I have the same model Bissell as you and this is going to sound silly....
The spray tank runs out of solution allot faster than you would expect it to. Remove the tank, dump out all the used stuff, and refill your solution tank.
You never know that it is empty until you dump out the waste tank! 20 minutes sounds about right for a full solution tank to run dry.
Good Luck! Thanks for using FixYa!
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
The brush has stopped turning when used in the upright position
I have one too and I'm trying to fix it as I write this.I also have an older version and I've had no luck.I've taken evey screw out ,spayed tweeked and tried everything possible.my solution would be to stay away from Hoover steam spin scrubs.I'm going to invest in one with brushes like a vacuum.Those that are easily replaced as well as the drive for it be it a belt or a turbine like I've read this unit has
Apr 20, 2010 | Kenmore 31913 Progressive Direct Drive...
My fusion just stopped. i was vaccuuming and it
One item to check is this: This unit has a temperature overheat device.
Unplug the unit for 20 minutes, then plug in and turn on the switch. If there was a blockage in the hose/cup/filters, this could cause the overheating.
If this does not resolve the problem, it will need disassembled and checked with a continuity meter to determine the component that failed (motor, switch, cord, or TCO)
Oct 25, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Turns off after 10 minutes of normal useage then comes back on 20 minutes later
it has a cutoff switch two stop it from over heating check it isent blocked up sumwhere in the fillters or the pipes
Oct 20, 2009 | Kirby G6 Bagged Upright Vacuum
Dyson DC07 motor overheats
the motor brushes are worn down and can be expensive to get someone to fit them for you so i think its time for a new cleaner
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Aug 01, 2009 | Kenmore Bagless Upright VacuumVacuum
Kenmore bagless upright Model # 116.35726401
There is actually an internal fuse in the vacuum. You may have blown this. The circuit board connected to the ON/OFF touch pad may be bad too but probably unlikely. There is also an overheat sensor that trips the vacuum off when it gets too hot. This could be bad preventing it from coming on too. All of these solutions, require you to open the vacuum to fix.
Sep 25, 2008 | Kenmore Progressive Bagless Upright with...
Motor and Lights stopped suddenly after vacuuming the stairs.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19809&thid=745467
Motor and Lights stopped suddenly after vacuuming...
Posted by Brigham81 on Jul 05, 2008
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse? Thanks, Brigham
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL2200 Bagged Upright Vacuum. It sounds to me that when the lights go out and it stops working that the motor is bad that you would have to replace the motor. It is still cheaper to replace the motor than to purchase a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vacuumstps working
there is an overheat stat which cuts out motor if insufficient air flow. there must be a blockage you hav'nt found - probably in the air path from the brush roll to the fan
Apr 01, 2007 | Kenmore 33078 Bagged Upright Vacuum
Vacuums Logo
82 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
