Question about Digi Electronics - Others
I encounter problem with my Apacer USB Flash Drive. Previously it was working properly. When I plug in the USB Flash Drive, a "Removable Disk" will be listed under the My Computer in Windows Explorer. But lately, when I plug in the USB Flash Drive, it didn't show up in the Windows Explorer. So I check the Device Manager. I notice a "?" on the USB Mass Storage Device icon. I remove the USB Mass Storage Device and restart the computer. Plug in the USB Flash Disk again and face the same problem. Then I use the CD comes with the USB Flash Disk and update the driver. After updating the driver, Device Manager shows that the USB Mass Storage Device is detected and no error reported. But the Windows Explorer still didn't show the Removable Disk. Later I realize that my Notebook supports USB 1.1 but the USB Flash Disk is USB 2.0. I guess the USB Flash Disk is supporting USB 1.1 because it works in the first place. How can I get the USB Flash Disk to work again?
Chodaye muri kha
Posted on Jul 25, 2009
Using an Integral 4GB flash drive in USB port, how do you switch between drives on the flash drive?
A flash drive is only one storage drive. It appears on the Removable Disk drive in the Computer file if it is plugged into a USB port. You can change and access different files on your flash drive if you click on Removable Disk in your Computer file.
Aug 06, 2013 | LG 32cs460 32" 720p Lcd Tv
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
J ai le mp3 tout le temps allume et il ne   fonctionne pas
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} ok tu peut essayer de la formater
Suivre les étapes suivant:
cliquer le : Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
essayer de la formater en fat 32 et fat nfts
Merci
uttam
Jan 13, 2010 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Hello,I cannot access my 1GB apacer mp3 so plzzz help me to start that...
Plug it in and see if it shows up in my computer if not then install the drivers off the CD that came with it
Dec 02, 2009 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Removeable Disk Not Recognised. I have my USB labelled SONY USB 2.0 I GB. once I plug it on my computer never recognised. So am asking you to get better solutions, Regards, charles
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 12, 2009 | Sony Electronics - Others
My Apacer 512mb mp3 was accedentally pulled out while data tranfering. Now it is not working anyamore.
Oct 27, 2009 | Acer Aspire 4315 Notebook
When I put my DaneElec 4GB USB Drive into my USB port, nothing happens. We have Vista.
Do other USB devices work when you plug them in the USB port?
If they don't then you have a faulty USB port otherwise the DaneElec is faulty or needs formatting.
Oct 18, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Transcend JetFlash V60 16 GB Pen Drive not working properly
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
Oct 05, 2009 | Electronics - Others
HOW TO FORMAT A WRITE PROTECT USB DRIVE
MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK.
I had same problem. I fix it with suggestion of 1st guest. I download program from site http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip, and program formated USB and he work fine now. TY for advice.
Jan 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Jan 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Electronics - Others Logo
421 people viewed this question
Top Digi Electronics - Others Experts
Are you a Digi Electronics - Other Expert? Answer questions, earn points and help others
