Question about Creative Labs X-Fi XtremeMusic Sound Card
I can not make my computer recognize the sound blaster card that i have put in. i have installed the drivers but no result. i get sound from the original motherboard jack but when i connect it to the sound blaster it doens't make any sound.
  • 564 Answers
  • Reseat your sound-blaster card.
  • Close the tower and turn on your computer.
  • Then reset your Bios.
  • Then save and restart.
  • Uninstall the old drivers.
  • Click Here to Install the drivers from the Website.
  • Then Restart the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks,
PREM
Posted on Apr 12, 2009
My creative sound blaster SB 0100 was not detected by my windows 7 when I intalled the driver it shows "hardware not detected" how can I fix this problem.
First install the chipset driver.
Then install the audio driver. Your computer will detect your sound blaster.
I've not...
Make sure you are using the right driver
Jun 06, 2011 | Creative Labs SB0100 Sound Card
System recognizes soundblaster live soundcard but not working no audio
control panel sounds and audio,audio you will find the necessary adjustments to make there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Sep 21, 2010 | Creative Labs Sound Blaster Live! 5.1...
Audio driver creative sound blaster 5.1
my omputer is sound problem i need sound card install the sound card in my computer...
Mar 09, 2010 | Creative Labs Sound Blaster Live! 5.1...
Pci intallation
WHEN YOU PLUG IN THE SOUND CARD WHAT DOES IT DO OR DOESNT DO?
IS THERE ANYOTHER CARDS PLUGED INTO THE MOTHERBOARD TOO.
DID YOU REMOVE OLD DRIVERS FIRST,
ARE YOU HAVING ANY OTHER PROBLEMS RUNNING OF SOFTWARE.
WWW.CREAF.COM
ADDRESS BAR TYPE
CREATIVE LABS SOUND BLASTER CARD DRIVER,
CREATIVE LABS SOUND BLASTER DOWNLOAD DRIVERS,
SOUND BLASTER TECH SUPPORT,
CANDYMANGANDY
Jan 27, 2009 | Creative Labs Sound Blaster Live! 5.1...
Sound card drivers can not installed
Your card isn't supported by Creative anymore, it is too old. As such, you would have better results by using a newer card. But the drivers are located here - http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=207&prodID=4851&prodName=Vibra%20128&subCatName=Others&CatName=Sound+Blaster
Dec 28, 2008 | ASUS P4VP-MX Motherboard
Audigy 2 sound card
I have different installation disks for Sound Blaster audio cards Including Audigy versions if you need copies drivers or software.
Nov 18, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Sound Blaster Audigy Prob
Dear
This usually happens to a PC with an Audigy card and uses a VIA chipset. The problem seems to be worse with the use of VIA Althlon chipsets but I can not concretely confirm that. Usually this will surface during driver installation with a message saying that there is no Audigy card installed. The solution that I found to work is to first manually install the card through device manager. In Control Panel->Systems->device manager, do a driver update by specifying the directory where you have extracted the Audigy drivers. This driver update will end up with a partially working driver that says "Audigy Audio Processor (WDM)" or "EMU10k1 audio". Once this is performed reinstall the driver normally by running setup.exe. If you can get the driver to partially install then the second time around the system will be able to recognize the installed audigy card.
In 2003, Creative finally releaased updated drivers for SB Live! and Audigy. The new drivers should solve the above problem for most people.
Oct 19, 2008 | Computers & Internet
Creative sound blaster 5.1 for vista
you have the real driver for your sound card if yes therefore unpluck the sound card then repluck it eventually after putting your computer off .then after you ve repluck it put it on and introduce the driver into the cd rom and instal it
Jul 25, 2008 | Compaq Creative Sound Blaster PCI 128...
Problem with Windows XP recognizing Creative Sound Card
It sounds like a software problem. Though you did the right thing by entering the bios & disabling the onboard sound. That should have been enough. Did you uninstall the old intergrated sound drivers before adding the 24bit card? Just about all the drivers & upgrades for your 4600 through Dell is Creative software & thats why your having a tough time. I would put everything back to how it was. Re-enable the intergrated sound & reboot! Run system restore & check that every thing is running right!! Look at this dell web site for the sound drivers you have at this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If you must, install a upgrade for your intergrated sound. Just so you can uninstall it after a reboot. Re disable the sound in the bios. Do not install your new card yet. While back in windows device manager you should be missing a PCI device. Shut down install the new sound card. Hopefully windows will want the drivers & all runs fine. If still no it could be a bad card (i know what your thinking but it's possible). The only thing left is the regestry is using the wrong PCI device.
Dec 26, 2007 | Creative Labs Sound Blaster Live! 5.1...
Creative Labs X-Fi XtremeMusic Sound Card Logo
79 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
