Question about Uniden 5.8GHz Dual Cordless Phone
Uniden Dect 6.0, the base keeps beeping
One of the bases on the phone beeps really loud once every couple of minutes. We have tried switching phones, unplugging it and rebooting, and nothing seems to stop the beeping
  • 1 more comment
  • krj118 May 18, 2009
    Mine does this too, and mine has no answering machine.
  • A Cagle Aug 17, 2012
    Tried all of the above... Nothing in their manual seems to address this...
    Perhaps we could ask them to replace the equipment? Let's all try.
  • 89 Answers
You have your answering machine set up to beep when you get a new message. Go through the menu for setting up the answering machine and turn that feature off.
Posted on Apr 16, 2009
Philips VOIP 841
Hello sir,
Try reloading skype again ....
Mar 05, 2008 | Computers & Internet
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
THE BASE SET OF MY UNIDEN 1480-3 CORDLESS PHONE NO LONGER BEEPS WHEN I HAVE A NEW MESSAGE. CAN ANYONE HELP?
You can set or change the answering system options from any handset.
Open the menu and select Ans setup then select Message alert and activate it!
Beeps will be on!
Oct 05, 2014 | Uniden DECT 1480-3 Black Cordless Phone w/...
Red light at top of handset blinks constantly
If that means, "charging," then it's time to replace the battery pack...
Mar 09, 2014 | Uniden DECT 6.0 Cordless Phone ID
What does it mean when it said hold find key for 5 sec
There's a button on the base station marked "FIND HS". Pressing this button will cause all the handsets to beep for a minute, so you can find handsets that may have fallen between the cushions on the couch or otherwise gotten lost.
For further assistance, either specify the model of your Uniden DECT 6.0 phone or select it from the list beginning here to download a copy of the manual.
Jun 18, 2012 | Uniden DECT 6.0 Cordless Telephone...
I have the Dect 1683 with three handsets. We had a hurricane and the power went out and not all three handsets read "Searching" and I get no dial tone. When the phone rings it rings but you...
Hello
Just unplug the base unit from AC wall power socket for a while, say for about 5 minutes or so, replugh the base unit to power socket again. Place each handset on it and synchronise it with the base unit. As you put it on, you will hear a beep sound. Now the ahndset ahs been synchronised with base unit. Do this for the other two handsets. OK.
Aug 30, 2011 | Uniden DECT 6.0 Cordless Telephone...
My vtech cordless reads out of range or no power at base, what is wrong?
Official solution to this issue:
Make sure base station serial number matches all handsets serial numbers.
If they don't match you will have to de-register the units.
De-register the base station by holding the find handset button for 10 secs or until the In Use light illuminates, release the button and then tap it once more. You should hear a short beep followed by a longer beep.
Press Menu Select and the press the following without pause - *7890#
You should now see Test Base at the top of the screen press the Vol up button until Test Handset is present.
Press Menu/Select and you should see SW Version displayed. Press Vol up button until you see regstr clear, then press Menu Select and then Menu Select again.
At the handset remove the battery for 15 secs and then place the battery back into the handset. You should see 1. Place handset ... 2. press # on the handset screen. DO NOT FOLLOW THE ON SCREEN DIRECTIONS.
Next place the Handset on the base station and press the find handset button for 4 secs until the In Use light shows up. Remove the handset and press the # button.
Your handset should now display Handset 1. You can do all the other handsets the same way.
Hope this helps!
Jul 25, 2010 | Vtech 9009111 Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8GHz Dual Cordless Phone Logo
1,996 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
