Question about RIM BlackBerry 8800
MY BLACKBERRY moistened WATER IS A BIT ME YOU PLACE A HAIR DRYER TELEPHONE WORK THE LESS THE SCREEN IS DARK
  • 561 Answers
If your BlackBerry gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Posted on Jan 14, 2010
My monitor takes long time to come on why
Your power supply board has a "flakey" capacitor on it.
It will soon fail, I can guarantee you that. The replacement component is likely less than a dollar, but figuring out which one it is can take a bit of sleuthing.
Try blowing hot air from the hair-dryer into the back when powering it on, it should speed things up a bit.
The solution is to have it repaired. The "Fixya" here is DON'T TURN IT OFF, because then you won't have to worry about it turning back on!
I have a monitor that I have been using the hair-dryer "trick" on for YEARS.
If I reboot the computer, and the monitor is already hot, I have to wait for it to cool before the hair-dryer trick will work again.
Have fun!
Feb 28, 2015 | Computers & Internet
How do I remove the lint from my hair dryer babyliss pro
Should be a screen that twists off. You can use a toothbrush to scrub the gunk off the screen, but you might need a mild cleaner, like window cleaner, to dissolve it. Scrub it a bit, rinse with water, let it dry.
When I do repairs, that's one thing I always do: clean the crud out of the lint screen!
Feb 15, 2015 | Health & Beauty
Went thru a water puddle it was deep, now the car wont stay started and the gas pedal no longer works
What year and what engine do you have ??
How long ago did you go through the puddle ??
You turn it over does it run on it's own for a bit before it shuts down ??
Do you know if it's an electronic throttle body ??
Apr 16, 2014 | Ford Crown Victoria Cars & Trucks
Samsung factory reset
inspect the data socket for liquid damage seen as green mold, white calcium residue. If present, clean using toothbrush or q tip moistened in tap water, dry afterwards with compressed air or a hair dryer.
Dec 22, 2013 | Cell Phones
What is special about ionic hair dryers?
I read a review top ten hair dryers which is the best and professional blow dryer for healthy hair. everybody can choose one. 10 Best Hair Dryers 2014 Review Buy it for curly hair
Feb 04, 2013 | Health & Beauty
Water Damage in blackberry
i have a pantech slate and it got full of water,.....i put it in water & that didnt work so i tryed a hair dryer....now it works perfectly fine
Mar 30, 2010 | AT&T Blackberry Curve 8300 Smartphone
My blackberry curve 8350 i got wet and it does not work. What to do to fix?
Once a piece of electronic equipment gets wet, you need to disassemble it, remove the battery and dry it carefully using a lint free cloth. Then use a hair dryer to dry it out. Do not put the hair dryer too close as you could overheat and damage the item. If you wait too long to do this, the water may have already fatally damaged your phone. Good luck!
Mar 01, 2010 | Nextel i850
Dark Screen, Lense focus gone and error code: E61:00 - Help!
In this situation (salt water) best thing is rinsing the equipment immadiatelly with tap water and drying it throughly and quickly (with hair dryer etc.) But its been three days, so the internal circuitry and metallic mechanisms are most probably affected from salt water since its highly corrosive. Now, you can send it to your dealer/camera manufacturer for throughly check and repair. I believe nothing you can do right now. And its probably still damp inside, means still affecting by corrosive salt water if you did not already dry it throughly.
Jul 08, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
No water from water spout
See if there is a sediment screen at the inlet to the filter from the faucet and see if it's obstructed or clogged. Obviously, make sure you are using the correct filter cartridge and that the filter discharge is also clean.
Mar 22, 2009 | Hotpoint HSS25GFP Side by Side...
Liquid in Main LCD Screen
Not a lot you can do for this problem, you could try taking all the removal bits off the phone, and drying them with a hair dryer on
low heat.
The chances are something will be fused in the phone.
AC/DC power and water don't go together.
Sorry I just noticed the date. A bit late, but you can change the LCD. It's easy to do and cheap to buy.
Jan 12, 2008 | LG VX8300 Cellular Phone
RIM BlackBerry 8800 Logo
127 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
