Question about Windchaser PACR10 Portable Air Conditioner
Exhaust fan making loud noises
We've had this unit for about 3 months. Last week, the exhaust fan started making a really loud, consistent noise whenever the exhaust started to run. I took the casing off the unit, but can't get to the fan to see what the problem might be. I know Windchaser offers placement parts. Is this something I can realistically do myself, or should I just get them to replace the unit?
  • 2 more comments
  • prm1 Jul 18, 2008
    same problem but it has just passed a year and two months but compressor still has warranty
  • niren_g Apr 22, 2009
    exhaust fan making loud noise whenever it get started.....it,s a double motor...fan
  • Walter Raymond II Jul 29, 2013
    these unts have a plastic blower cage inside the lower section of the unit. It takes some doing, but it is possible to get the unit apart by removing the hillips screws. Once you open the blower chamber you will most likely see the plastic ring around the outside of the blower cage is broken. You can use a pair of pliers and remove this completely and reassemble the unit and it will work fine. The other thing you might fnd is debris in there which you can clean out at the point where you have it opened.
  • Anonymous Mar 25, 2014
    When accelerating from start to about 15 mph I hear a rubbing noise. Then it stops at higher speeds. There is no gear slipping.We just had a brake
    job done a few weeks ago. They replaced rotors , along with brake pads, etc. When we heard the noise we took it back to dealer where the brake job wss done. They re checked it found all ok. They told us that it was a transmission problem, and offered to replace it for$4000. They dont do repairss on transmissions. They say it may be the carrier bearing in the transmission? Any idea what the priblem might be and how much it might cost to repair?
  • 725 Answers
Still under warranty. put it back together and don't tell anyone you took it apart. Call the factory numbers and have them fix or replace it...let us know what happens..kraxytech
Posted on Sep 11, 2007
SOURCE:
Saturn Ion running loud and rough
Check for other loose heat shields.
The shield you removed would allow more noise to enter the cabin too.
Mar 15, 2014 | 2003 Saturn ION
Strange One-3.5 in a 03 Maxima with 51k miles, makes a sound like an exhaust leak or a leaking head gasket on a cold engine start, seems to go away after the engine hits operating temps. Also has anyone...
sounds like exhaust manfold to cylinder head gasket is blown, make sure you have got the tire pressures correct, get your shock absorbers checked one may be partially siezed
Nov 16, 2017 | 2003 Nissan Maxima
2001 crown victoria lost oil pressure and just cut off now when i start the car after five mins the car start ticking really loud
i have a 2001 crown victoria was driving down hwy car made loud noise and shut off had it towed home got it started and has NO power almost couldnt get i in drive way, had been making a slite noise before that and bucking
for about 4 months in the last 3 weeks noise was getting louder. Was told could be timing chain how likely is this and how do i check it.
Sep 30, 2012 | 2001 Ford Crown Victoria
Loud exhaust noise on startup
2008 GMC Envoy is only equipped with one of two engines:
4.2L (254") 6-Cylinder SFI
5.3L (325") V-8 SFI
Niether of these engines are equipped with an EGR valve, so I guess the probability of that being the cause of your noise is pretty much zero to none.
If you believe the noise is being caused by the exhaust ststem, then the only way to verify that is to inspect the exhaust system. Leaks are easier to verify with the engine running.
With that said, there is also a Technical Service Bulletin (TSB) that is published by GM that addresses customer complaints about loud noise that is being caused by the electro-viscous engine cooling fan clutch. Some people describe it as exhaust noise and others describe it as the engine "racing" or "roaring".(even though the tachometer (if equipped) will be reading normal)
It basicly says that it can make noise on startup due to high rpm of the fan which goes away once the electric solenoids open and allow the fan to start free-wheeling. GM says this is normal operation. You might want to check to be sure this is not what you are hearing. (it can be pretty loud)
May 26, 2012 | 2008 GMC Envoy
My 3 year old Viking refrigerator starting making really loud noises today...what can I do avoid a repair bill???
If the loud noises sound like a fan blade hitting ice you have a defrosting problem.
You can try unpluging the unit removing the contents then doing a manual defrost with a fan blowing into the unit for a bit over 2 hours then restarting the unit to see if the noise has ceased.
If it is a noise associated with the compressor you can try pushing it gently in it's floating mounts to try and reposition the unit so the vibration absorbers are functioning properly again.
Lastly if it is the condensor fan making noises break out the crevice tool and remove the lint from the coils. If you have pets this is very important.
Sadly if the problem repeats in less than a week after doing the above the dreaded serviceman / repair visit will be required to islolate the cause or source.
Vikings' website:
http://www.vikingrange.com/consumer/footer/contact_us.jsp?id=cat50013
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Viking 42 in Built In Professional...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
DVD PLAYER FAN MAKES REALLY LOUD NOISE IT SOMETIMES GOES AWAY WHEN I TAP THE BACK OF THE FAN SOUNDS LIKE ITS JAMMING
When fan's shaft got dry, it start vibration in spinning and produce lound noise. Lubricate exhaust fan shaft with good quality machine oil.
Thanks.
Nov 18, 2009 | Samsung HT-Z310T Theater System
Hi. my vent made some funny noises last week and
Check the fan blades and see if it's being restricted.Another method is remove the fan blade turn the unit on and see if it spins if it doen'nt tap the motor gently and see if turns.If this works the motor brushes are worn
Sep 28, 2009 | Broan-NuTone N-QT100FL Combination Light...
Noise of microwave exhaust fan
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
Mar 25, 2008 | Microwave Ovens
Noisy fan
We had our house built with the same Nutone fan/light units in all 4 bathrooms. Moved in in 2002. One of the units starting making a loud noise last month. I popped the plasic cover off the light, then carefully pulled out the bulb, then unscrewed the wingnut in the middle. That allowed removal of the light assembly. Then I had access to the blade and motor. I found a lot of dust had collected on the motor and blade. I blew most of it off with compressed air (like what you would use on a computer), then used an electronic cleaner on the motor, then wiped off the blade and motor with a clean cloth.
I then crossed my fingers and turned on the fan.... It worked! It was quiet again. I waited a week before posting this. The fan is used every day. It is still quiet today.
If it ever needs replacing, I saw that Nutone sells the motor alone for about $22, that's a lot better than replacing the whole unit for around $70.
Mr. J.
Nov 17, 2006 | Broan-NuTone N-769RF Combination Light Fan...
Windchaser PACR10 Portable Air Conditioner Logo
514 people viewed this question
Top Windchaser Heating & Cooling Experts
Jakes Auto Care
Donni Steen
Pete Norton
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
