My ibm t30 will work with it 256mb ram all the time, but the 1gb ram only works some of the time.
  • Dick
    Dick May 11, 2010
    From your description of the problem it is impossible to determine the cause. Likely your memory is incompatible with your system, but you must provide more information to be sure.
  • 108 Answers
It seems 1 gb ram you have tried to install is not compatiable with this ibm t30. I will advice you to check the type and frequeny of 1gb ram you bought it will be written like DDR 400MHZ OR pc2 533/667 MHZ please check these two things and it should be matching with the original 256 ram which was working.
Posted on Aug 22, 2009
It looks like common problem: my OLD T30 can see only one 256mB memory slot. Does it make sense to install one 512 mB unit? Can T30 recognize 1gB memory? Thank you in advance
Hello
Yes, you system will support up to 1GB of ram, so, if i were you i would suggest that you buy a 1GB chip, this will give you the best performance upgrade. And, ram is so cheap at the moment, so, i think it will be the best option.
Let me know if you found this helpful.
Kind regards
Andrea
Sep 09, 2010 | IBM ThinkPad T30 2366 Notebook
How can increes speed of computer.
you are using Thinkpad T30 2366 and if it has a low RAM (memory) you can upgrade that. I check your computer specs online and what I saw is this P4-M 1.8 GHz but unable to verify if it has 256mb RAM. If it does you can upgrade that to 512mb.
you can look on this website { http://www.edgetechcorp.com/memory/upgrade.asp?cid=27556 } just to check the compatible RAM for your computer.
Mar 26, 2010 | IBM ThinkPad T30 2366 Notebook
After adding 256 MB with existing 256 MB showing only 256 MB in BIOS instead of 512 MB
The problem could be One of the 256MB RAM is not deatected as not inserted properly or due to malfunction.
Download this small application.
Here is the link
http://www.cpuid.com/download/cpuz/cpuz_153_setup.exe
Download this application and run (you don't need to install this software).
Check in which SLOT your RAM is Working using the above application.
Try to insert it properly again.You can also try by interchanging The RAM, yso that you can pin point whihc of the RAM is malfunctioning in case of MALFUNCTION.
Rate this Solution.
Jan 07, 2010 | IBM ThinkPad T30 2366 Notebook
T30 working with 1/2 memory RAM
WoW!, Ubuntu Lover.
Thums up for you Man, Live Free, Linux for Human Beings.
Regards,
Waqar.
Aug 06, 2009 | IBM ThinkPad T30 2366 Notebook
Thinkpad T30 2367-23S will not use 2GB Ram Card
noway max is max. buy yourself a 1gb and don't try to beat the system or lose it.
Mar 03, 2009 | IBM ThinkPad T30 2366 Notebook
Vgn a170b ram upgrade problem
your ram IC not compatibel or not work well with your laptop
it's recentlly happen
please rate
Jan 21, 2009 | Sony VAIO VGN-A170B PC Notebook
T 30 IBM MEMORY PROBLEM
Hi!
Call 800-IBM-SERV and describe the problem. Say that you heard that there's an "engineering change" available to correct it, described in document MIGR-44772.
Repair should be free within the warranty period, and probably free even outside the warranty.
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Jan 10, 2009 | IBM ThinkPad T30 2366 Notebook
Ram install problem
with RAM there can be a few problems
1) the frequency of ram which *********** board supports might be less than the freq at which the ram you are puttin works, hence in this case RAM wont work on this mother board and ull have to get the RAM replaced
2) some motherboards do not support a 2 x 1 GB RAM where as they might support a 1 X 2 RAM (if you do have 2 mem slots for ram)
and then there is the most trivial problem of the slot not being clean or arm not being put properly, i can think of ne other reason for the ram not working properly..
cheers
Kushal
Aug 21, 2008 | IBM NetVista PC Desktop
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
