Question about Kenmore 44109 / 44102 Side by Side Refrigerator
Amana side by side refrigerator compressor locked up
My refrigerator is 6 1/2 years old. the freezer stopped working and a repairman said that the compressor was locked up. He also said that it would cost at least $500.00 to fix it. Any suggestion? Could a power surge cause this to happen? Thanks, Marcus
More than likely, if there were any power issues,it would be low voltage that would cause it to overheat and lock up shaft to bearing. But power surges can cause problems if they are sustained as well. Nameplate rating on these is 115 volts and it will operate up to 10% above or below that voltage (+/- 11.5 volts). But when you get to the fringe voltages for extended periods you increase the risks of failures.
Posted on Sep 19, 2007
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
These will help.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
My Amana 26 cu ft side by side quit cooling entirely in the freezer and the refrigerator. Is it worth it to get a repairman or should we just get a new frig. This one is 6 years old
I suggest get help with repairman.6 year old is not very old.Refrigerators have life more then 8 to 10 years.The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:---
This will help. Thanks.Helpmech.
Oct 24, 2011 | Amana 26 cu. ft. Side-By-Side...
Have an Amana fridge, 22.6 cu ft, 12 years old, side-by-side, water/ice on door. Freezer quit working over a 3 day period. All the food thawed. Not sure if the fridge part is getting warmer also -- not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Jun 20, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Compressor under warranty, how much is the labor to fix it?
How old is it and is the repairman an indipendant company or the manufactuers repairman?
If its older than a year, and/or the repairman is indipendant then yes you probably will have to pay for labor.
Expect between 250 to 400 for the labor.
Some units have no labo warranty from the manufacturer.
If less than a year and the repairman is actually employed by AMANA directly and not a subcontractor or "authorized rapairman" then you may have a labor warranty.
Dec 28, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Frigidaire side by side
booster on compressor not condesor, if you needed a "boost" to run compressor sounds like you got bad compressor.
Feb 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Dec 15, 2007 | Amana ARSE66MB Side by Side Refrigerator
Kenmore 44109 / 44102 Side by Side Refrigerator Logo
206 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
