Question about Canon Pixma iP6600D InkJet Photo Printer
Canon Lines in picture and colored word doc
Hi I have tried printing pictures but there seems to be horizontal lines in the pictures same thing goes for colored word documents or anything for that matter... What could be wrong ..
    Novelist:
    Scholar:
  • 167 Answers
You should check whether the color ink is out or not. If so replace it with a new one. Otherwise just cleaning the print head will solve your problem. To clean the head Go to control panel > open printers and faxes > right click printer icon > Click properties > Find the option "Clean print head" or somthing sismilar. Use it and your problem could be solved. Note: Some printers have seperate software utilities to clean the print head.
Posted on Oct 06, 2007
  • Deepu Amalan
    Deepu Amalan Oct 06, 2007
    If nothing works try changing the color ink cartridge.
SOURCE:
I have a brother all in one MFC 685 CW &having problems printing
Not sure where you found the recommendation to use Windex on your print heads but chemicals should be avoided. It sounds like you have damaged so of the head elements and now they are leaking. There are specialized fluids for cleaning print heads or plain old water will dissolve ink as well. Too late for you however if the heads have been damaged they will need to be replaced.
Oct 06, 2016 | Brother MFC-685cw InkJet Printer
HP LASERJET 3800 PRINTS THIN BLACK LINES ON PICTURES
that print head is clogged,
do the clean cycle shown in the manual;
new cartridge time if cleaning does not work.
all things work last week but now.
nothing new here and for sure pesky printers
and for sure not used every day. (this keep them going more reliably)
made back in 2008, so is getting long in tooth and on most this full cleaning of the whole printer is advised. ever do that?
per manual?
rtm?
https://support.hp.com/us-en/product/hp-color-laserjet-3800-printer-series/500934/manuals
Oct 09, 2017 | HP Color LaserJet 3800
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Horizontal lines on display and printed image
I suspect your camera has a defective CCD which is quite common for the A75.   Canon is aware of the problem and has issued a recall for affected cameras.  I have had mine repaired under this recall.  Here is a link with some pictures which show what the problem looks like.
http://www.imaging-resource.com/badccds.html
I hope this helps
Nov 28, 2008 | Canon PowerShot A75 Digital Camera
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
My printer makes lines through all the pictures i try to print
I had same prob with Epson but went into preferences/main and changed from text and graphics clicked to picture or best picture..problem solved.
Aug 26, 2006 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
160 people viewed this question
Clive
Clive
old marine
old marine
Ekse
