Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Dual dishdraw bottom Ok, top one wont start cycle,F2 comes up
F2 sign comes up after a few secnds, makes a Knocking sound first.
  • 144 Answers
Try swapping the motor rotors between the two drawers and see if the fault changes drawers, also check for anything stuck under the motors or and damage to the plastic of them. cheers
Posted on May 13, 2009
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
I have a Fisher Paykel 605 double DD. I have an F2 error message. There was a frozen rotor, likely from disuse over the winter. I replaced the rotor and it still stops and shows the F2 display. There
Not sure if you have fixed the F2 problem yet. The rotor cavity may look clean but sometimes there is a piece of bone or seed stuck inside the channel connecting rotor cavity with pump sump. Take the rotor out and the drain filter out. Take a rigid thin wire and run it inside the channel connecting the two.
Also get some white vinegar and with a tooth brush rub it inside the rotor cavity to ensure all dirt is removed. The rotor speed sensing is done by the hall sensor sitting underneath the cavity. It is not visible from top. The sensor could be reading incorrectly. IF still no luck then Run in diagnostic mode - (but make sure you do not try any other function than what is mentioned here otherwise you could damage dishwasher).
DishDrawer Diagnostics can
only be entered in Power Off mode, ie. When there is no display on the LCD or the
badge LED's are off. Diagnostics is entered by holding the
Keylock and Start/Pause buttons simultaneously for 5
seconds. Ensure that
Keylock is pushed first.
All LED's and LCD segments (except keylock) are illuminated. Press Power button and display shows HO in red background. Press Start/ Pause. You are now in hardware diagnostic mode. Open drawer so that you can see inside. Press Start/ Pause a few times until FU shows on display. At this point press Keylock and water should flow in. Press Keylock to turn inlet valve off after water is collected under the wash arm (don't cover wash arm). Press Start/ Pause again and P1 will display. Press Keylock to turn rotor motor on and water will swish around. Press Keylock to turn motor off within a few seconds otherwise flooding could occur. Next press Start/ Pause once so P2 displays. Press Keylock to run rotor again but this time it will pump out. Let it run until the water is pumped out. Press Keylock to stop pump. This should test the rotor in both forward and reverse direction.
PRESS POWER BUTTON ANYTIME TO EXIT DIAGNOSTIC
If the hardware test worked ok then turn mains power to dishwasher off and on and start normal wash cycle. If there is still an F2 problem then hall sensor is faulty and needs replacement. Not easy to do and best left to technicians. By the way each dishdrawer has separate controller - so one drawer could be working fine and the other not.
May 10, 2014 | Fisher and Paykel Dishwashers
Engine knocking
Well a low tone knocking noise at startup is usually a worn engine bearing.
You should be able to have someone listen to the engine to tell if it is coming from the top or bottom.
Feb 01, 2014 | 2000 Dodge Grand Caravan
F2 error code drawer
In order to find the availability of spare parts for your model of dishwasher it would be helpful if you can provide the Product Code from the label on the front of the main unit.
May 23, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Jan 02, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
Greetings. I have a Fisher & Paykel dishdrawer - the top drawer appears to have lost power mid cycle and the lid has not retracted - no led display - no response from the buttons. The bottom drawer...
Describethe inside of unit,any wear on it anywhere, the rack the dishes go on is it plastic coated? is it wore with rust comeing though on tips here and there?
Mar 07, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Dishdrawer model DD603 gives fault F2 (Motor). Unit has only been used a few times. What to do? Out of warranty.
Ok this is what you do you need to swap over the motor rotors from top drawer to bottom drawer. check for anything jammming the rotor etc when you take it out. if it works with the other drawers rotor then you need a new motor rotor. cheers
PLEASE GIVE ME FEEDBACK
Mar 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
300 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
