Question about Toshiba Satellite A135 Notebook
No power to TV. Checked all fuses and power lead
Power supply green light comes on but unit does not power up.
When you say 'checked leads' does this mean you checked to see if they were firmly plugged in? or that there was power on the power leads... If there is power, you probably have a 'smoked' drive. If no power on the leads more than likely a blown fuse in your power supply.
May 03, 2015 | Power Computers & Internet
Not getting any power through to tv. plug/fuse ok. what next?
There should be a round black rod about 1/8" in diamater, that is the circuit breaker, press it to reset and if it comes on and stays you have solved the problem, if not best get a service tech.
Dec 19, 2014 | Audio Technica Televison & Video
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Wharfedale LCD2710HDAF no power to tv, checked cable and changed fuse a few times, new power lead? or is this a common problem?
Hi.
The power cord must be checked using a multimeter. The test is done reading impedance (ohms) between plug's prongs and contacts to TV power board.
If the power cord is OK and there is no power, then the problem is the power board inside the TV.
Regards.
Ginko.
Dec 04, 2011 | Televison & Video
Sony wega KE-42M1 .power lead ok . no power at tv. (no standby or power light showing at on switch). house power went off , when it came on tv wouldn't work
This confirms that the main power supply which is the SMPS is faulty.
The fuse could have failed and must be checked, if the fuse fails the SMPS is confirmed to be faulty due to the power outage.
please check the links below for tips and support:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Sep 21, 2011 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
No power to tv
hello,
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Jun 01, 2010 | LG 32LG30 32 in. LCD HDTV
My tv will not turn on. I have check the fuse and
Power supply board is dead.Replaced the power supply should solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Mar 30, 2010 | Samsung LE32A41B 32 in. HD-Ready LCD...
No power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Oct 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
C21T7BA TV will not power up.
check the internal mains fuse usually connected to the mains lead via the on/off switch .good luck farr64
May 02, 2009 | Mitsubishi VS-60607 TV
Toshiba Satellite A135 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
