Question about Toshiba 50H81 50" Rear Projection Television
Tv shutting off
The tv will shut itself down (but the red light stays on) after a while. Sometimes it takes longer than others. It will not come back on until you turn it off and wait a while. If I just leave the tv on after it shuts down, the red light will begin to blink.
  • yves1 Nov 10, 2007
    HD-56G886 shuts down after few minutes of running....
    Any ideas? Somebody mentioned that there might be a problem with ballister ("baluster"?) board.
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 08, 2008
SOURCE:
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
Hitachi 55VF820
well..the control board has this sort of issue. sometimes, if you turn if off long enough to reset itself, this may clear..otherwise, it's a replacement of a non inexpensive component..
what's your technical ability like?
Mar 22, 2008 | Televison & Video
Heard a pop, tv went off, then doesnt come back on
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 23, 2010 | Hitachi 50VF820 Projection TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
On off switch
clean front panel contact switches on/off vol- vol+ use contact cleaner .
Dec 03, 2008 | RCA D52W19 52" Rear Projection Television
Zenith z44sz80
the light next to the power light is the lamp indicator when it blinks red it means there is a problem with the lamp . if its orange it means its getting close to the end of its life span.let me know if you need anything further .
Apr 13, 2008 | Televison & Video
Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Jun 14, 2007 | Hitachi 50EX20B 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
89 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
