Question about Car Audio & Video
Speaker Removal I can't get the rear speakers out of my 1991 Honda Prelude. It looks like there are 3 or 4 bolts underneath the plastic cover to remove the actual component. But i don't wanna break the plastic cover. How do i remove the cover without breaking it?
The plastic piece should just come right off
Posted on Apr 12, 2009
Attempting to remove plastic molding around passenger rear vent motor, having difficulty. any help would be appreciated
This is more difficult than it looks because the rear trim panels must be removed in a certain order as they overlap at their edges.
First remove the rear seat.
Remove the step panel from the floor near the side door opening.
Unbolt the 2 seat belt anchors.
Remove the trim panel below the lift gate (rear hatch opening.) Pry the screw plugs out with a small screwdriver and remove the screws.
Pry out the rear speaker grill using a flat blade screwdiver that has been taped to prevent scratches.
Remove the rear speaker mounting screws. Pull the speaker out and unplug the connector.
Remove the passenger side trim panel mounting screws.
Use a panel clip removal tool and pry the clips that hold the trim panel then lift the panel away.
Installation is the reverse of removal.
Apr 07, 2011 | 2002 Honda Odyssey
How do I remove the rear speaker in my 1998 Pontiac Grand Prix? Does it involve the cover on the inside of the car? We can't seem to find any way to remove it from the inside of the trunk. It looks like...
Most of the time you get to the rear speakers by opening the trunk and looking up from the trunk that's where the wires connect and the bolts that hold them in and they come out the bottom in the trunk. with all the bolts removed the grill inside the car can be remove as the bolts that hold the speakers in hold the grilles on too
Mar 08, 2011 | 1991 Pontiac Grand Am
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
How to remove the rear seat of a Honda Ridgeline 2010.
1. Pull the plastic panels under the seat bottom straight forward to remove them.
2. Remove the six bolts (14mm) holding the seat and center seatbelt in place.
3. Pop the two small plastic covers at the top and behind the seat using a trim removal tool or screwdriver tip covered in masking tape.
4. Lift the seat straight upward.
5. Remove.
The Service Manual states a 35 ft lb torque and must be re-installed in a certain sequence for the 6 seat anchor bolts (not the seat belt bolts). When putting the rear seat back in install the bolts in this order. (1) center left (2) center right (3) left lower (4) right lower (5) left upper (6) right upper.
Nov 09, 2010 | 2008 Honda Ridgeline
How do you change out a left side mirror assembly on a 2005 town and country?
1. Pop off the triangular piece that is just cosmetic on the upper flat part of the mirror where it is attached to the van.
2. Under this piece are two visible bolts which you will need a Torx driver to remove.
3. Open the passenger door all the way open and remove the 3rd bolt, which is exposed from the outside of the car.
4. Expose the wiring harness plug by doing the following:
a. Pull off the door weatherstripping along the top of the door and on the pillar (the part of the car to the left of the windshield) Do not completely remove the weatherstip - simply pull it away enough to execute the next step.
b. Remove the plastic pillar cover: it simply snaps in. Pull hard and it will pop off
c. Lift up the plastic cover over the speaker on top of the dashboard. This piece goes all the way across the dashboard. Simply lift it up enough to get your hands underneath it. There is no need to free it from the passenger side.
d. Follow the mirror wiring harness around the rear of the speaker (the side nearest the engine) and unplug it from the female connector at the right-rear of the speaker. There may be a wire clip at the left-rear of the speaker that you will need to get the wire out of.
5. Unplug the wire, remove the mirror, replace the mirror, reinstall everything
hope its work
Jan 11, 2010 | 2005 Chrysler Town & Country
Radio wiring diagram
2001 Honda Prelude Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Ignition Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
pls rate
Jan 09, 2010 | 2001 Honda Prelude
Mazda protege rear strut replacement 02
they're underneath the plastic deck cover in the back, where the speakers are. -just a few plastic fasteners and the wire connector for the rear light, and it'll pop right off. -just did it myself this weekend
Jan 03, 2010 | 2002 Mazda Protege
I dont know how to install stereo speakers in my citroen saxo VTR near the rear seats. how can i do this?
First you have to remove the old ones...
You cannot just clip out the rear speakers, as the cover over them is attached to the rear panel (2 door Saxos)
In order to take out the rear speakers, from what I remember...
1) Take out rear seats
-Get yourself in the car through one of the front doors
-Once inside face toward the rear seat
-Reach for gap between where the upper and lower parts of the seat join
-Pull the bottom half up and towards you
-Once it is vertical lift straight up to detach from pivot
-Get it out of the car to give you space
2) Undo 2 bolts
- Having just removed the lower part of the seat there are now 2 bolts visible 1 located each side of the car, next to the rear speaker panel.
- Undo the bolts, they are long so require lots of twisting until free
- Remember where the washer sat and place in safe location out of car
3) Lift up rear window seals
- Open rear windows
-Lift up the rubber seal which lies on the bottom part of the window
-(It is attached all the way round the window trim, only lifting it up is neccessary)
4) Remover upper seatbelt bolts
- Locate rear seat belts (side belts only)
- Locate top of seat belt fixing point
- Remove circular plastic covering on top joint of each belt (1 each side)
- This reveals seat belt joint bolt (1 each side)
- Undo bolts and place safely outside of car
- (Same for front seat belts required)
- Locate front seat belts
- Locate front seat belt joints at top of belt.
- Remove circular plastic covering (1 each side)
- This reveals bolt (1 each side)
- Undo bolt and place in safe location
5) Lower rear seat
- Open the boot
- Clamber in
- Locate where rear seat meets plastic trim (each side of car)
- Locate small plastic lever (each side of car)
- Push small plastic lever towards the front of the car (both sides same time)
- Meanwhile push rear seat gently towards front of car (helps if have a friend)
- This will lower seat
- (You do not want seat lowered completely, once seat is free in movement leave resting in normal position)
6) Remove rear speaker panels (requires trusted + competant friend)
-Friend Get in car sit where rear seat was on driver side (for space)
-You sit front seat passenger side
-You locate where rear speaker panel ends beside front door
-You pull rear speaker panel away from end at door towards opposite side
-You will notice part of rear speaker panel detach from car
-Friend and You pull off remainder of speaker panel from its poppers
-Notice lump of plastic preventing complete detachment from car
-Careful to prevent damage Friend and You need to move rear speaker panel towards front of car and up
-Remember plastic will flex, but is also capable of snapping
-Manipulating this action will get rear speaker panel detached from car...although still on the seatbelts themselves.
Notice how speaker is joined to hidden part of rear panel, rather than metal body work.
To remove rear speaker undo the 4 torx screws holding speaker in place, alongside wire joint (wire with plastic adaptor at end)
Do what you needed to do, and then return car to normal state by effectively reversing the above instructions.
(I accept no liability for any action you undertake from following these instructions.....yadda yadda)
If any problems contact a Sax-p I.C.E section expert, or if incounter any difficulties that the above cannot solve, any car audio installer can help, alongside most garages, including Citroen Dealerships.
The instructions above probably took longer to type than to actually perform, estimated time for completion is 40mins-1 hour.
Oct 24, 2009 | Car Audio & Video
Change window gear on 99 civic
this is from a 97 civic should be the same. remove the door panel. remove 1 screw and pull handle, remove 1 screw and plastic cover over door opener handle. remove speaker cover and three screws underneath. remover window crank. then remove the door panel (held on with plastic plugs...just pull panel toward youself).
to remove the regulator ("window crank gears") Remove the glass held in with two 10mm bolts. The regulator itself is held in with six 10mm bolts. Remove these bolts and remove the regulator. (installation is reverse). Note: pay attention to the Idler arm track (highlighted in green) I think this one is directional (the front has to be at the front and the back has to be at the rear)
Feb 23, 2009 | 1999 Honda Civic
Removing front and back speakers in 1991 Grand Am....
There is a lot involved in replacing these speakers. You should also know that the original factory speakers are 10 ohm speakers. This means that if you replace them with new speakers (most of which are 4 ohm) you run the risk of damaging the stereo, the speakers, or both. This can also cause a potential fire hazard in your car. If you want new speakers, you really should look at installing a new stereo as well.
To get to the back speakers, you will need to remove 2 bolts located under the front edge of the rear seat (bottom). After you remove the bottom, you will need to remove the rear seat (back). This involves removing the bolts that hold down the rear seat belts, which is a large sized torx bit (T-45, T-47, or T-50... Don't remember which). After removing these, lift straight up on the seat back to remove. Now remove the deck brake light housing, and the bracket that holds it. Now the deck cover can be removed. Be careful not to bend it too much getting it out from under the side trim on both sides.
For the front speakers, you must disassemble a good portion of the dash. Remove the screw holding the light switch and the wiper switch housings. This screw is underneath each housing. Once removed, there are dash mounting screws behind them. These screws (and many of the other dash screws) are a smaller torx-bit (T-10 or T-15, don't remember which). Sometimes they use a 7mm bolt. There is a cover panel just above the glove box. This panel is held on with 2 screws located in the glove box. After removing this panel, you will find 2 or 3 bolts holding on the dash. Last but not least, you will find 2 bolts inside each of the defroster vent grilles. These grilles just snap out for easier access to the bolts.
1991 Pontiac Grand Am Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4" Round
Car Audio Front Speakers Location: In Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6" x 9" Oval
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Nov 30, 2008 | 1991 Pontiac Grand Am
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
