Question about Panasonic Viera TX-32LX70 32 in. LCD TV
Cant get the stand off a panasonic 32 inch TX 32LXD60 to put on the wall
  • 718 Answers
TX 32LXd60
Lay the tv face down on a flat surface. Do not scratch the screen ! Use a cloth.
Remove the 4 screws above the stand. Pull stand out. Replace screws.
You can get Operating Instructions from;
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
enter the model number- click search- and download the Operating Instructions . The Operating Instructions will illustrate the stand.
Posted on Apr 12, 2009
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Cannot get ITV or Channel 4 on newly aquired DTV, why is that?
The only thing I can think is happening is for some reason it's ignoring these stations. I suggest you try going to the factory settings for it. Then retune, it might clear the tunner's memory.
Feb 26, 2010 | Televison & Video
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
How to remove stand from panasonic tv model no tx-32 l m d 70
Place tv on its BACK,with the screw holes underneath.Remove the four screws,remove stand,and turn tv over to rest on the sceen (on top of a towel)or some other cloth so as not to damage the screen,and replace screws.The reason for placing the tv on its back when taking out the screws,is that,unless you have a magnetic screwdriver when removing the screws the are difficult to remove as they are deeply recessed.
Apr 09, 2009 | Emerson RP6248 AM/FM/TV Radio
How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Jan 31, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Can not remove the rest of the TV stand
I am the owner of the Panasonic TX-32LZD60, and finally managed to solve the problem myself.
So for anyone else out there with a similiar problem, you need first remove the two screws at the back of the TV which are low down. Take of the small plastic casing. Underneath you will see two rows of a total of 8 screws, which go through a black metal plate. Remove these and the stand will slide out. Not bad for a girl!!
Dec 18, 2008 | Televison & Video
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Panasonic Viera TX-32LXD60 on screen display
On your TV remote, to the right of the "0" is an "i" - press it!
May 22, 2008 | Televison & Video
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
4,842 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
