Question about Garden
Lawnboy F series Engine - how to remove PLATE AND COLLAR ASM
I'd like to clean the exhaust ports on my Lawnboy with an F100 engine. (mower model R7268).
I removed the blade but need to remove the square plate from the cranshaft to remove the muffler. (Plate and Collar Assembly Lawnboy part 677525).
I've tried a gear puller but no luck. the lawnboy service manual section 3 simply says remove adaptor plate. https://lookup3.toro.com/ttcGateway/acrobat/manuals/lball08.pdf
Any help removing the plate would be appreciated.
Shaft is tapered plate just slides up on shaft, tap with hammer several times if want break loose,sometimes moisture has rusted it or excess heat has swelled it on tight, i had to take a drimel tool will cutting disk to remove mine,then clean up shaft with file or sandpaper to smooth,little grease an new collar ready for blade.
Posted on Jun 15, 2009
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy help
ck. governor linkage connections
Jun 18, 2013 | Garden
Need the B&S e-mail address for customer service regarding lawn mower info. thanks
here's your address
http://www.briggsandstratton.com/engines/support/contact.aspx
Feb 08, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Where is the egine model number located on a Lawn
Go to www.lawnboy.com and input the model number of the MOWER and probably any of the serial #'s if you don't have yours. More options and info will pop up and you may get your engine model info from there. I hear that the Duraforce engines are all the same model?
Jul 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 | Garden
What is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Mar 29, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
1,638 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
