Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
I have a Dyson Animal. Roller bar won't turn/belt intact
Makes a horrible noise when "carpet" selection is chosen. Bar is clean and free of any obstacle. Suction seems fine.
  • jimmyzark Apr 18, 2009
    Dyson DC14 Animal (purple) Roller bar/brush turns a little then stops when switching from bare floors to carpet. Brush/belt intact. Occassionally makes horrible grinding type noise. I immediately shut it off. Any idea if this is a belt problem/defect. Unit is about 3 years old
  • 7 Answers
Actually, I'm the poster who said I have the same problem, but it turns out I have the DC07 animal, not the DC14, but perhaps the solution is the same for the DC14 and it doesn't cost anything! I called DYSON and they told me the clutch needed to be reset, so she had me recline the vacuum from its upright position, lay it on it's side, turn the carpet/bare floor dial slowly back and forth between the two settings about 6 times and it apparently reset the clutch and now the cleaner bar spins normally and there's no more loud grinding-type noises. She said if that didn't work, the next step would be to remove the bottom protective panel (secured with the three large plastic screws) and lift the entire cleaner bar (do not remove the belt) out about an inch or so and then reinsert it and reattach the bottom plate. I hope this helps your problem. Good luck.
Posted on Apr 18, 2009
Hi my dyson dc07 animal has suction but the brush bar wont turn. If I turn it on there is a horrible noise. The belt is still fine
The belt is probably worn or stretched. When this happens the belt won't turn the roller brush when it is against the carpet. Here is a link for the manual and links for the belt you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Nov 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Belt wont turn makes a loud noise when put on carpet setting
If this is a Dyson with a protected belt that can't be replaced then it will have to be sent out to Dyson or get a Dyson servicepersonnel to check it over - protected belt motors are difficult to fix by yourself. If its clicking all the time, then it means the belt has to be replaced. In the mean time check that there are no obstructions on the beater bar and behind it and also check that the brush stop roller at the top of the hood is in the right position. It should move automatically when the handle is swung down in normal operation.
Feb 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
When I put the vacuum in position to use on rugs, it makes a horrible grinding noise like something is stuck.
Hi If the Dyson model you have has a protected brush model (i.e. roller wheel at the side that goes up automatically to turn off the brush roll) then the belt will have to be replaced by a Dyson engineer. If its not that model and doesn't have the brush roll stop function, check that the roller beater bar and the brush are properly aligned, also checking the main dust channel isn't clogged.
Feb 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Correct position of beater bar on a Dyson DC14?
I had the same problem. I removed the brush from the machine. The brush should move freely when removed. If it doesn't move freely, pull the ends from the brush, both ends come off(one will have a rod fixed to it). I would suggest you clean the ends and the inside of where the ends sit on the brush. I applied a little grease on both end housings(inside end housing) if no grease available try washing up liquid. Put the brush ends back on the brush. I then spun the brush to check that it moved freely. It should move freely, if it does fit it back on the machine and it should be silent. If you cant get it to move freely I suggest a replacement brush. Tip: I used a blunt knife and placed it through the belt to avoid removal of the belt. Good luck. Cheers Jason
Jan 19, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The beater bar makes a horrible clunking noise when I turn it on
I just came from the repair shop. There is a recurring problem with a bearing coming out. Repair guy turned it on & said that loud noise is a symptom of that exact problem. This is a warranty item, as is the belt & on/off switch. Dyson comes with a 5 year warranty, so call their 800 number to get the name & address of an authorized repair shop.
Jun 08, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Nov 11, 2007 | Dyson DC14 Full Access Bagless Upright...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
3,016 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
