Question about LG WM-1832C Front Load Washer
We get a de code
We got our washer back from being in storage for 10 mounths. we pluged it in and hooked up the hoses and tried to wash clothes. when we closed the door and tried to start it the door lock sounded like it ingaged, but doesn't and we get a de code.
  • 1,543 Answers
A "DE" is a drain error, but a "dE" is a door error. If it was in storage, I'd look for damaged wire(s) to the door lock switch caused by a mouse. It is less likely that the door latch itself needs replacing.
Posted on Apr 19, 2009
My lg front loader I close door push start get clicking noise at door switch and code de door error is it the door switch it fell off truck on to door face.
Error code 'DE' means a problem to lock the door.
Check that the door hook goes properly into the hole.
Check that you didn't put a lot of clothes in and these are pushing the door glass (maybe a test without clothes would be best).
Check that the door closes good and there are no broken pieces from the door.
If the problem insists, probably you need to change the electric door lock. Here is a video for your help. Generally, it is a cheap part. If you cannot do it yourself, you need to call an engineer.
LG Washer Front Load Door Switch Repair DE code
Mar 01, 2017 | LG Washing Machines
Nf code, new cold water valve, cleaned screens, drain good, uplugged and pluged back in still no cold water
trying turning the water off. disconnecting the hose at the valve and hooking it up again.
Feb 02, 2015 | Washing Machines
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
Help! I live in a foreign country and my washer just started to do this. The water doesn't come into the machine to wash the clothes. The pipes are hooked up correctly because I had just put a load in 30...
Check the two water hoses on the back of your washer. Turn off water supply and unscrew one hose at a time and check the small filter screen inside the connection on the washer. Also check and make sure the electric water control valve is working properly. ( this is the plastic fittings your two water lines screw into. Remember this valve is controlled by the washing machine timer and (on off ) control.
Hope this is helpful
Feb 11, 2011 | Frigidaire FEX831CS Top Load Stacked...
Washing machine flashing de
I haven't seen a DE is it maybe DC? these are the known codes
DL - Door unlocked when washer is running DS - Door is open when washer is running NF - Washer tried to fill but was not successful due to clogged water lines or closed water valves. ND - Washer is not draining it can also mean that the unit senses a small clog or frozen hose. DC - Unbalanced load prevented the washer from spinning. When the weight of the laundry is about 1kg the center of the weight gets shifted. redistribute the load and restart or add more clothing.
SUDS - Too many suds are detected, the unit will be put on hold until the suds are reduced the it will go back on. when it completes the wash it will flash END and SUDS. make sure you use HE (high efficiency) detergent
Oct 10, 2010 | Samsung Washing Machines
De comes on the front and wont drain wm1814cw
the machine is clogged is th hose kinked,try to push the start buton again,you should hear the pump come on and try to drain.when it stops,push the button again,when the door unlocks take cloths out.And put 1/2c of bleach in drum and let it soak a few hrs.Now start washer no clothes this may do it,after cycle put clothes back in and run clothes through full cycle.When ther done.Put in Draino-Drain opener gell only and let it set over nite,then run heavy duty cycle this well clean washes and clean pump.
Jul 26, 2010 | LG WM1814CW Front Load Washer
My washing machine gets stuck when it is going to start the rinse cycle
Top 10 frontload washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.Note some models send a sig nal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, too much detergen, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the termister/heater is out.
Your repair Manual with photos and tech data HERE
I will leave that on there for a while but it takes up broadband so print that manual out and keep it close to that washer.
Feb 10, 2010 | LG WM-2277HW Front Load Washer
I have a Kenmore front loader washing machine that won't spin or drain. What is wrong?
Feb 07, 2010 | Washing Machines
It smells like musty water inside the machine and is leaving that smell on clothes and towels
it is very good q
advice in secret do 2 things
1-{ washing without soap without clothes in maximum temperature like 95 oC in cotton programm } do that every mounth
2- after complet any washing programm leave door of m/c open for just 15 minutes
thanks
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Mar 17, 2008 | Washing Machines
LG WM-1832C Front Load Washer Logo
244 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
