We just bought Medion M2080 notebook. We stragle with problem there is a anouncement about Bios password. Can any give advice how to solve this problem?
I bough a new medion laptop and forgot what my password was and now cant get in
Which password: windows or Bios? In any case just take it back from where you bought it and they'll explain you.
Apr 10, 2015 | Medion Computers & Internet
I forget my password bios
To remove the BIOS password all you need to do is reset the BIOS.
To reset the bios all you need to do is open the side panel of the CPU unit and you shall find a electronic battery on the motherboard. This is the CMOS battery. Press on the clip to remove the battery from its slot and wait for a minute. switch on the PC without the battery and switch off after 30 secs. now reconnect the battery and your BIOS reset is done.
I think the issue should get resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote for best answer.
Nov 29, 2012 | Medion MD-40954 Notebook
I forgot my bios password and i cant get into laptop
You can take out the CMOS battery if you disassemble your laptop. This will erase any presence of a BIOS password.
Jul 29, 2011 | Medion md40298 Notebook
How can reset bios user password
Its very simple process..
1)open BIOS setup by pressing F2
2)go to advance option
3)go to security and reset master password
If your problem not solved then clear CMOS memory by suitable jumper on motherboard.
or format your computer if no any way is remaining..
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 17, 2011 | Dell Inspiron 2200 Notebook
How do i reset my bios password
I am afraid that such kind off issues could only be solved by motherboard replacement, unless you can contact Dell support with a proof of ownership of this notebook.
There is also this service which can help you crack the BIOS password:
http://www.pwcrack.com/security_chips.shtml
Dec 10, 2010 | Dell Latitude D830 Notebook
Bios password for medion laptop
If u forget the BIOS password then u can login again only after resetting the password .that can be done by taking the CMOS battery out and put it in again
Thank U
Please rate me as it will cost u just one click
Oct 28, 2009 | Medion MD-40954 Notebook
How do i clear bios on Medion ram 2020 notebook
not sure whats so tricky is really rather simple the laptop must come apart there is a battery on the mother board it must be removed for aboput 10 minutes this will total clear the bios replace the battery and reassyemble laptop if that dont fix it you may need to flash the bios to repair it.
Feb 20, 2009 | Computers & Internet
F2 in troubleshoot not work because of the password which is
theres a program called spotmau ;you can download a free version off net( google "spotmau")first off download it then unzip contents and create a boot disk and copy contents to disk.( there is a instruction file included in the zip of how to do) then turn off pc making sure cd is still in tray.reboot.system will startup with spotmau and a menu page will come up.there is a section to remove all passwords choose it.when done remove disk and reboot to windows.The other way is to partially strip pc to remove rtc battery for a minute or so then replace battery and put pc back together.
Jan 03, 2009 | Medion md40298 Notebook
Bios password
What you will need to do to clear a bios or power on password is 1- transfer ownership of the machine at Dell's support site
(link #1), then 2- contact Dell support by telephone for the master code (link #2). You will need the machine or configuration id, the number at the bottom of the initial white screen.
http://support.dell.com/support/topics/global.aspx/support/change_order/tag_transfer?~ck=ln&c=us&l=en&lnki=0&s=gen
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=E21A18454B4A6550E030A68F27286358&doclang=en&cs=
Aug 11, 2008 | Medion md40298 Notebook
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
