Question about Mtd 22" Yard Machine Push Mower
I HAVE A MTD YARD MACHINE 12A446B729. RUNS FIVE MINUTES THEN STOPS AFTER WARMS UP STARTS UP AFTER COLD. SPARK PLUGE CLEAN AIR FILTER CLEAN
    Problem Solver:
  • 6 Answers
Was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Posted on Apr 14, 2009
Mtd 13AI607H118 Mower starts,when it warms up it stops, I wait and it starts and shuts down again/
Possible I/C cutting out when it warms up therefore it stop producing spark so swap out with a known good one
Jun 14, 2014 | Mtd 46" Dozer Blade, Fits All & Yard -...
The mower starts runs very weak , for a few minutes then completely stops...oil is good,gas tank full with new , fresh gasoline
i would try first of all replace the fuel filter and check clean or replace your air filter. Personally I think it is going to be the fuel filter that is clogging and causing this. And for little cost replace the plug and make sure it is gaped right.
May 15, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
YARD MACHINE MOWER NOT A YEAR OLD YET AND IT CRUDDIES UP EACH NEW SPARK PLUG AND SMOKES, NOT RUNNING WELL. ITS RUNS REAL FAST AND THEN REAL SLOW, SPUTTERS. I HAVE ALWAYS KEPT AIR FILTER CLEAN AND OIL...
Return the mower if possible for warranty repair or call MTD with the issue. MTD mowers typically are good quality and should run like new for a long time with proper care. Depot may give you a 1-800 number instead of customer service so before you load up the mower talk to them. It does sound like a bad valve seat or rings either one is not typical wear and tear.
Jun 07, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
994 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
