Question about Cameras
When I slide the lens cover to turn on the camera, the camera turns off and the lens retracts.
  • rrbundy Apr 13, 2009
    my G500 minolta does not stay on when I open the lens cover
  • 15,935 Answers
I would say the camera is trying to extend the lense, however meeting a minimal resistance is shutting back down.
Lint, sand or other particle may have lodged in the lense mechanism.
As you power on next time... give it a few good thumps on your palm, ans see if you can get ti to dislodge.
It sounds strange, but there are very tight tolerances in the lense, and even an eyelash or hair can make it not want to extend.
If there are no errors on-screen - your problem is a mechanical binding and should be expertly cleaned if you cant get it un-stuck manually.
Thanks for using FixYa!!
Posted on Apr 13, 2009
  • 10,594 Answers
Please intimate model and brand of camera to look for its technical details.
Use "add a comment" button to reply.
Thanks.
Posted on Apr 12, 2009
When i try turn on my camera it makes a buzzing noise, as if its trying to turn on but the lens does not come out any solutions?
Check to see if the retractable dust covers on the lense, if one of or both are knock out of there track that they slide in.
Mar 01, 2012 | Kodak EasyShare M883 Digital Camera
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Camera won't turn on, just beeps
first check the battery... charge or replace it... else reset the camera or repair
Sep 05, 2008 | Olympus Camedia D-510 Zoom Digital Camera
Lense will not extend, or if it does it retracts after a short while. Batteries appear to be OK
After talking, without any success, to your expert I tried experimenting. It seemed like the sliding lens cover was the main reason for it to behave as it did. It turned out that the lens cover had a worn track and did not always operate the lens motor switch to open it, or pressure on the cover caused the lens to retract. All it needs is a new sliding cover.
Jul 18, 2008 | Olympus Cameras
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
Lens Retraction
Since your camera should be still under warranty, best thing will be to conntact to the appropriate factory service center for correction of the problem. Good luck!
Aug 06, 2007 | Canon PowerShot SD600 Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
