Question about JVC HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System
I have JVCD HX-D7 system. The'Protect'message appears when i turn it on. The'protect' message appears and the system turns off please help
  • 2 more comments
  • peke_viper May 09, 2009
    I have JVCD HX-D7 system. The'Protect'message appears when i turn it on. and the system turns off by it self. I turn the stereo on but without connecting the speakers and still the same.
    can sombody hit me out!!
  • MANUEL TORRES May 11, 2010
    you will need to check speaker wires. go ahead and disconnect wires and connect them again properly.. make
    sure that they are not touching, or damaged. also you can try a reset
    unit by having it on and disconnecting power cord for 1 minute. if this
    doesn't solve problem there's mechanical problems inside of unit and
    its protecting itself from getting more damaged by turning off, and it
    will need service by a technicia
    you will need to check the speaker wires. go ahead and disconnect wires and connect them again properly.. make
    you may want to check speaker connection wires. go ahead and disconnect wires and connect them again properly.. make sure that they are not touching, or damaged. also you can try a reset unit by having it on and disconnecting power cord for 1 minute. if this doesn't solve problem there's mechanical problems inside of unit and its protecting itself from getting more damaged by turning off, and it will need service by a technician.
    Problem Solver:
  • 5 Answers
I had the same problem, it could be that there are a number of different problems that cause this error code. I noticed my unit was extremely hot even when it was turned off. Try unplugging it for half a day and see if it works then, maybe only for a short while. If it's just overheating get a larger system ($10) fan (may need to drill some new holes to mount it) and flip it so it blows into the heatsink area for the amps. Drill a series of holes in the upper casing for proper air flow. you may see the amps are scorched as well they need to be replaced (easy) for about $40 for the pair.
Posted on Oct 31, 2009
I Have a JVC HX-07 that turns off itself after few seconds showing PROTECT message on display?
the unit may be damp inside.there is dew protection on most new units.It sometimes happens when units are used in the basement.unplug it and plug it back in again and see what happens
Jan 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
"PROTECT" message in display.
two cables of a speaker were touching each other.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
My jvc hx-d7 radio is turned on in 2 seconds it shuts down to protect mode how do i take protect off ?
You can't. The main amplifier module will probably have a channel blown. The unit is detecting this and tripping into protect mode to stop further damage occurring. Needs to go to a repair place. sorry. ps If you get sound briefly before it trips off then it may just be a speaker wire shorting out! worth checking
Nov 07, 2009 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Jvc model no.ca-hxd7 system no. hx-d7
Check back speaker wires! this is protection mode! There is a short circut! look for stray wires touching metal or each other!
if this does not do it then unit will have to be fixed by a pro!
Please use the ratings and help keep this area FREE!
Jan 23, 2009 | JVC MX-GT88 CD Shelf System
I TURN MY STEREO ON AND A MESSAGE APPEARS ON THE SCREEN THAT SAYS "PROTECT" AND IT POWERS DOWN. JVC MODEL NO. CA-HXD7 SYSTEM NO. HX-D7
OK this is the protection mode! There is a short circut! unplug and check all back speaker connections making sure no stray wires are touching metal or each other ! if this does not help the short is inside of unit and will have to be fixed by a pro!Please rate my answer and help keep this area FREE! THANK YOU!
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Sep 27, 2008 | JVC HX-C6 Shelf System
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect mode
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Feb 08, 2008 | JVC HX-D7 Shelf System
"PROTECT" message
I've got a jvc hx-d7 i am working on for a friend, he had it repaired once at a shop with this same problem, they replaced two 42v 2200mf caps. and one A1273 this solved the problem for 8months now its doing it again. I am trying to locate the A1273 to repair it again. Hope this helps.
Dec 25, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
430 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
