Question about HP Computers & Internet
Hp computer. hard drive light is solid yellow ..non working
Hp computer. hard drive light is solid yellow then turns out. Monitor stays in standby. fans are working on mobo and psu. I can hear the hdd spin. Whats up?
any help would be great. thanks
    President:
  • 357 Answers
Hi 2xcapers
This could be a problem with your IDE or SATA cables that connect your Hard Disk to your Motherboard. Try replacing these before you try the next solution.
The constant yellow light usually indicates a crashed or non-functioning Hard Disk. You can take this to get repaired and only the data where the "Spindal Pin" crashed will be lost, otherwise the Hard Disk should still be fine. The screen does not come on during the event of a crashed or corrupted Hard Disk, so this is another indication that there is a problem with the Hard Disk.
Please remember to give this solution a FixYa! rating.
Happy Easter
BearWeb
Posted on Apr 12, 2009
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: hp computer. hard drive light is solid yellow pc non working
What has transpired is the power supply is bad. Electrolytic Capacitors inside have failed. These capacitors relate directly to the voltage power rails of the power supply. They are filters.
Little more detailed.
Your computer power supply converts AC electricity into DC electricity. (A flashlight battery is an example of stored DC electricity)
AC comes into input Electrolytic capacitors. Goes to a rectifier bridge, and on through various other components. Along the way, this DC voltage is considered 'Raw'. It needs to be a steady, 'clean', supply of DC voltage. There are Electrolytic capacitors used in the final stage, to convert the 'raw' DC to 'true' DC.
In a computer power supply the Electrolytic capacitors are the weakest link. They are usually the first component to go out.
You computer power supply converts AC voltage into three DC voltages. 3.3 volts, 5 volts, and 12 volts. These are the power rails.
When one, or more Electrolytic capacitors are weak, they make a weak voltage rail.
To simplify explaining the construction of an Electrolytic capacitor, let's just state they are small aluminum 'cans', and have a seal at one end, or both ends. Inside there is an Electrolytic paste.
This paste can break down, and when it does it forms a gas. (Hydrogen gas) This gas expands inside the 'can', pushes up on the seal/s, and makes Electrolytic paste ooze out.
So much paste loss, and the capacitor can operate in a weakened state. Too much paste loss, and the capacitor fails.
ALL the lights in your computer use less than 1 Watt. EACH fan uses 2 to 3 Watts. A harddrive just sitting there spinning, may use up to 5 Watts.
A processor uses 55 to 125 Watts! Depends on the make and model.
Since the power supply is to weak to provide enough power to turn the processor on, the harddrive isn't activated. It just sits there and spins. No Boot record on the harddrive is found, so no Operating System is going to be running. (WinXP is an example of an O/S)
This essentially means No computer! Harddrive activity light indicates yellow, then goes out. There is no harddrive activity.
No signal from the computer, because the computer isn't working.
Monitor stays in Standby, because there is no signal from the computer.
Power supply failure is 70% of computer issues.
Why?
Owner neglects to keep the inside of the computer, and the power supply clean. Doesn't use a can of compressed air for computers regularly.
Also there is another issue that the owner has nothing to do with.
Capacitor Plague.
http://en.wikipedia.org/wiki/Capacitor_plague
Solution? Replace the power supply.
I know the above info may seem like a 'Hard pill to swallow', but as stated. A weak power supply will still spin fans, and light lights.
Harddrive may spin, or spin up, then stop.
The processor isn't getting enough power.
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Please can you help us. when we turn the computer on the monitor light stays blue with the screen remaining black, when we turn the tower off the light stays blue when it usually has the orange standby...
There is probably a conflicting setting in your power management options. My recommendation is that you check the monitor setting in Windows and see how you have it set up. In Windows it is under CONTROL PANEL>POWER OPTIONS. There are a few differences between WINDOWS 7 and XP from here on out, but in general, do not select a scheme and do not select any hibernate, standby, or sleep modes. If you stick with a simple power saving option, like "TURN OFF MONITOR: After 15 mins." you should not have any further problems.
Many of the Windows "green schemes" will not work right with different combinations of BIOS, Hard drive, motherboard, and monitor. It is best to avoid them, unless you are very patient and willing to go the trial and error route. Good Luck!
Mar 08, 2011 | ViewSonic VX2235WM Monitor
How do I turn off yellow on my hp monitor? yellow light on monitor stays onm after computer uis shut down.
Push the power button. The yellow light it to indicate that the monitor is idle or that it has no signal, and will stay on as long as the power is on to the monitor.
Jan 30, 2011 | Computers & Internet
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Computer shuts down
Please visit the below link to solve your problem.Due to some problems I was unable to send you the whole solution so please visit the site.
http://www.ehow.com/how_113600_troubleshoot-computer-wont.html
Thanks And sorry for the inconvenience.
Please rate me for this solution if it works for you.
  • Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szt64gb5
  • Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  • Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szsjH6o9
    Jul 06, 2010 | Dell Inspiron 530 Desktop Computer
    Lg Flatron 17" monitor turns on you see the green light then
    it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
    Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
    Have compaq nx7010 can power up but screen blank and hard disc light (between power and mains power symbols) not staying on. have tried removing battery and refitting which has worked once before but now...
    The HDD light is not meant to be on solid, it comes on only when the hard drive is actually working. The situation you're describing is usually just a lockup in standby.
    Although you're onthe right track with the battery, To reset the power, unplug the AC cord, remove the battery and then hold the power button for 30 seconds. Now put the battery back plug it in and turn it on. It may give you an error about not being able to resume, this is normal.
    If this doesn't work get back to us with more info: does it beep when it turns on, how many times, longs/shorts.
    Did you try plugging and external monitor into the laptop and rotating displays to see if your backlight is out?
    Ok, giver a try and let us know.
    Chris
    May 24, 2009 | HP Compaq nx7010 Notebook
    Hp computer. hard drive light is solid yellow pc non working
    Why?
    Capacitor Plague.
    Apr 12, 2009 | Sony VAIO Digital Studio PCV-RX540 PC...
    Magnavox 15mf605t/17 15'' LCD HDTV won't turn on
    Have similar TV. If it is set to the PC source, it goes into standby when there is no signal, like a regular monitor. Even though the monitor is in standby, you can still press the Source button to change to, say, HD input, and will use the familiar on/off action when pressing Power on the remote.
    A little weird, but I've gotten very used to it.
    Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
    Black screen not booting
    check both your power and video connections to the monitor, sounds more like a monitor power issue.
    if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
    Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    Computers & Internet Logo
    408 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
