Question about Sony VAIO Digital Studio PCV-RX540 PC Desktop
Hp computer. hard drive light is solid yellow pc non working
Hp computer. hard drive light is solid yellow then turns out. Monitor stays in standby. fans are working on mobo and psu. I can hear the hdd spin. Whats up?
any help would be great. thanks
  • 2xcapers Apr 12, 2009
    so can i use a voltage tester on the out leads of the power supply to check? Just curious , I got the computer from a friend and if UI can fix it for just a PSU ...then great
  • 2xcapers Apr 13, 2009
    well only checked the yellows and they show 12 volt
  • Sony Master
  • 5,660 Answers
What has transpired is the power supply is bad. Electrolytic Capacitors inside have failed. These capacitors relate directly to the voltage power rails of the power supply. They are filters.
Little more detailed.
Your computer power supply converts AC electricity into DC electricity. (A flashlight battery is an example of stored DC electricity)
AC comes into input Electrolytic capacitors. Goes to a rectifier bridge, and on through various other components. Along the way, this DC voltage is considered 'Raw'. It needs to be a steady, 'clean', supply of DC voltage. There are Electrolytic capacitors used in the final stage, to convert the 'raw' DC to 'true' DC.
In a computer power supply the Electrolytic capacitors are the weakest link. They are usually the first component to go out.
You computer power supply converts AC voltage into three DC voltages. 3.3 volts, 5 volts, and 12 volts. These are the power rails.
When one, or more Electrolytic capacitors are weak, they make a weak voltage rail.
To simplify explaining the construction of an Electrolytic capacitor, let's just state they are small aluminum 'cans', and have a seal at one end, or both ends. Inside there is an Electrolytic paste.
This paste can break down, and when it does it forms a gas. (Hydrogen gas) This gas expands inside the 'can', pushes up on the seal/s, and makes Electrolytic paste ooze out.
So much paste loss, and the capacitor can operate in a weakened state. Too much paste loss, and the capacitor fails.
ALL the lights in your computer use less than 1 Watt. EACH fan uses 2 to 3 Watts. A harddrive just sitting there spinning, may use up to 5 Watts.
A processor uses 55 to 125 Watts! Depends on the make and model.
Since the power supply is to weak to provide enough power to turn the processor on, the harddrive isn't activated. It just sits there and spins. No Boot record on the harddrive is found, so no Operating System is going to be running. (WinXP is an example of an O/S)
This essentially means No computer! Harddrive activity light indicates yellow, then goes out. There is no harddrive activity.
No signal from the computer, because the computer isn't working.
Monitor stays in Standby, because there is no signal from the computer.
Power supply failure is 70% of computer issues.
Why?
Owner neglects to keep the inside of the computer, and the power supply clean. Doesn't use a can of compressed air for computers regularly.
Also there is another issue that the owner has nothing to do with.
Capacitor Plague.
http://en.wikipedia.org/wiki/Capacitor_plague
Solution? Replace the power supply.
I know the above info may seem like a 'Hard pill to swallow', but as stated. A weak power supply will still spin fans, and light lights.
Harddrive may spin, or spin up, then stop.
The processor isn't getting enough power.
Posted on Apr 12, 2009
  • joecoolvette
    joecoolvette Apr 13, 2009
    Yes, you can check the voltages coming out. I would like you to know however, that this is not a true test for a power supply. You need to test those voltage rails under a load, for a true test. This takes a load analyzer, and they AREN'T cheap!
    Most tech's have a spare power supply for this type of test. We just plug in the spare power supply, and away we go! lol!
    Power supply's are a relatively inexpensive item, so they aren't repaired, just replaced.
    You are going to be testing a live power supply. I advise you to use all safety cautions, and don't get in a hurry.
    I would also like to advise, that you use rubber dishwashing gloves on your hands. Seems a little 'Over the top', I know, but I want you to be safe, above all else!
    WORK ON A TABLE!
    Power supply plugged into the surge protector, Power On button pushed in.
    Set the Multimeter to DC voltage. Set it to the scale that goes up to 50 volts.
    Use the Positive (Red) lead to the voltage wires. The Negative lead goes to ANY Black wire. (Ground)
    You stick the test lead down in the socket hole, and touch the metal terminal down in there. Each wire has a metal female terminal on the end of it.
    I'm willing to bet you find the 12 volt is bad. (Yellow)
  • joecoolvette
    You might check the other voltages also. As stated though, a voltmeter doesn't give an accurate test. The power supply needs a load on it, and an Analyzer is used to check the Psu. Too bad, you don't have a computer around, that you can borrow a power supply out of for a test.
2 Suggested Answers
BearWeb
  • 357 Answers
SOURCE: hp computer. hard drive light is solid yellow ..non working
Hi 2xcapers
This could be a problem with your IDE or SATA cables that connect your Hard Disk to your Motherboard. Try replacing these before you try the next solution.
The constant yellow light usually indicates a crashed or non-functioning Hard Disk. You can take this to get repaired and only the data where the "Spindal Pin" crashed will be lost, otherwise the Hard Disk should still be fine. The screen does not come on during the event of a crashed or corrupted Hard Disk, so this is another indication that there is a problem with the Hard Disk.
Please remember to give this solution a FixYa! rating.
Happy Easter
BearWeb
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
Computer shuts down
Please visit the below link to solve your problem.Due to some problems I was unable to send you the whole solution so please visit the site.
http://www.ehow.com/how_113600_troubleshoot-computer-wont.html
Thanks And sorry for the inconvenience.
Please rate me for this solution if it works for you.
  • Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szt64gb5
  • Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  • Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szsjH6o9
    Jul 06, 2010 | Dell Inspiron 530 Desktop Computer
    What does the red light mean next to the power button?
    The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
    Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
    My computer turns on but my monitor screen stays blank my key board lights dont come onim wondering if this is my harddrive because it doesnt make any noise when i turn it on
    Its highly unlikely that its the hard drive as a computer will still show a post or splash screen without a hard drive being installed.
    Is the computer making any beeping sounds?
    Aug 03, 2009 | HP S3120N Pavilion Slimline Desktop...
    Hp computer. hard drive light is solid yellow ..non working
    Hi 2xcapers
    Happy Easter
    BearWeb
    Apr 12, 2009 | HP Computers & Internet
    Emachine - T6420 - Monitor on stand by, no picture, fan running non stop, hard drive power on, screen blank, monitor in yellow not green the programs would end after 10 seconds---if you opened...
    Most likely your video card is broken. To check if the motherboard isnt broken either, I would suggest you test usb, sound, and other features of the motherboard.
     If your motherboard isnt broken then you have to buy a "pci-e graphics card" at your local store. Shouldnt cost much, about $40-70. Hope that helps.
    Jan 02, 2009 | E-Machines T6420 PC Desktop
    Black screen not booting
    check both your power and video connections to the monitor, sounds more like a monitor power issue.
    if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
    Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    Emachines 1900+ gets power to the monitor and computer but wont boot
    There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
    Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
    Sony VAIO Digital Studio PCV-RX540 PC Desktop Logo
    1,912 people viewed this question
    Top Sony Computers & Internet Experts
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
