Question about A4tech IRW 5 Mouse
Logitech wireless optical mouse caused window to jump back to starting window. True if opened a folder then subfolders, or when surfing the net. Like hitting the backspace key. In Word doc, cursor would stick in upper left corner. Pulled it and stuck on old mouse to solve the problem. Batteries are fresh. Drivers up to date, as are all windows software. Any clue how to get it wrorking again? It's been great for over a year or maybe two.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
You might want to clean underside of mouse with a non- abrasive solution . and soft cloth, micro fiber if possible. Then if necessary unplug device reboot,and re install with your product cd. not much else i could recomend.
Posted on Apr 12, 2009
Logitech mouse causes scroll function to stop working on my computer
A different driver or replace wireless mouse hardware
May 14, 2017 | Logitech Cordless Mouse
64-bit Windows 7, logitech keyb+mouse
I can't find your keyboard, but there again I don't have all the details so, if you'd like to start here :-
http://www.logitech.com/en-us/support_downloads/
Enter the required options to get to your particular keyboard, you should be able to find out if there's a relevent driver for you.
May 10, 2010 | Logitech Wireless Access Duo Optical...
I have a logitech wireless mouse for my emachines laptop,do do i set it up so i can use it instead of the won the laptop has built in?
Hi , i find a seperate mouse is alot better then using the mouse laptops have built in....it will help you out alot.
Expecialy when you surfing the web or something , the onboard sometimes cause's you get erritated as its very sensitive, i would rather stick to a seperate mouse
Hope this helps.
Have a great Day
Dec 29, 2009 | Logitech Wireless Access Duo Optical...
My Logitech wireless mouse is not tracking consistently.
hello,have you tryed cleaning the bottom of your mouse any dirt of debre can cause a bad mouse curse movement also have you checked to make sure you have updated drivers for your logitech devises ?
Mar 31, 2009 | Logitech Wireless Access Duo Optical...
My Logitech LX5 wireless optical mouse has never worked properly
hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
My Logitech MX310 Optical Wheel mouse is not working!
Try changing battery, but if you got it in 2007 it may be time for a new one.
Oct 19, 2017 | Logitech Computers & Internet
Left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
May 16, 2008 | Logitech Wheel Mouse Optical
Jumping mouse
I would take canned air and blow out the optical sensor on the bottom of the mouse. You could also try changing out the mouse pad. Most times when this happens something is causing the optical sensor to sense the wrong movement...i.e. dust, dirt, crumbs. Make sure to give it a thorough cleaning. Maybe use a little Isopropyl Alcohol on the sensor with a foam swab.
Feb 01, 2008 | Microsoft Wireless Optical Mouse USB...
A4tech IRW 5 Mouse Logo
81 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
