Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Renegade bra underwires
Underwires have escaped from my bra into the belly of the machine during the last wash. It seems to be working just fine, but I'm worried they may cause some damage in there. Is there any way how I can pull them out myself?
  • 641 Answers
It probably get between the clothes tub and the outer tub. If it gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove it through the port. To access to it, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Good luck !
Posted on Sep 11, 2007
What is the difference between a molded, contour, push up, and padded bra?
Hello, Lata -
molded bra - has cups made of a synthetic material and shaped by a machine using a heating process; the cups of a molded bra hold their shape when not worn
contour bra - also has shaped cups like molded bras but have more structure; the shaped cups are lined or even padded and may have underwires; the cups of a contour bra hold their shape when not worn
push up bra - makes the wearer look as if she has more cleavage than she has naturally; they tend to have under wiring and padding on the cup sides or in the lower sections of the cups
padded bra - has added material inside the cups to help make the wearer have a larger bust line and enhance cleavage
See information on these web sites:
Dec 18, 2017 | Clothing
The underwire of a bra came out and got caught in one of the holes. Now when I wash clothes it wash for 2 seconds then stops. It keeps starting and stopping so the clothes are not getting washed.
Try removing the power overnight by unplugging it or flipping the breaker. It might be a memory thing noticing all that strain on the drum, underwires eh? :>)
Just thought, there is a very delicate setting which gives very, very little agitation, silks or woollens I think. Make sure you are not on that setting for delicates.
If that doesn't fix it, you need an engineer.
Dec 01, 2016 | Miscellaneous
Is it possible to reset the arxd 169?
Your machine may have a drain trap which can be unscrewed to see if any foreign materials have entered the pump. If not you may have to release the pipe from the drum to the pump to see if any kirbie grips, loose change or even bra underwires have made their way down and jammed up the pump. My wife and kids are a nightmare I have this issue constantly. If you do this and all is clear check the pump is spinning it may have failed.
Jul 29, 2014 | Washing Machines
Broken underwires in certain styles of bras
cut down a hanger, then thread through bra where the underwire is broken
Aug 28, 2013 | Cell Phones
Bra Underwires slipped through the holes in the washer drum ... how can I get them out? EIFLW55HMBO.
possibly using a long pair of thin tweezers/a piece of stiff wire with a small bend in it.because if that fails the only other way is to remove the front door seal!
Jul 24, 2011 | Electrolux EIFLW55I Washer
Servis M6602W Washing Machine making scratching noise as drum spinning, I believe there is something gone through the holes in the drum and rubbing along the outside. How can I get access to...
There is no easy way to access the space between the inner and outer drum, unless you count cutting a hole in the inner drum and then welding it back up again afterwards. But it's hard to do this without leaving the drum unbalanced and prone to damaging subsequent wash loads. On some machines you can gain a very limited access by removing the drain tube running from the bottom of the drum to the pump. If so then you may be able to use long forceps to remove the item but may have to rotate the drum and tip the machine back and forward as you do so. Not easy when you're beneath the machine, so get strong-armed assistance.
What most often causes this problem is one or more bra underwires and they can be really difficult to fish out again, especially if they get chewed up and bent. Eventually the underwires often get chewed up and are then small enough to pass down to the trap just before the pump, so make sure that you regularly check the trap for debris as it may damage the pump or cause blockages if left unattended. If this has caused your problem then prevention is easy: never machine wash underwired bras.
Good luck, please take a moment to rate my reply.
Sep 17, 2010 | Washing Machines
Kenmore front load washer
Machine is draining slow...probably from debris caught in dain hose or pump filter. Many people find safety pins, loose change and bra underwires lodged in the drain trapping lint, threads and other items which are narrowing or blocking the drain. The machine will only go into spin if it drains within a few (timed) seconds. Otherwise, the machine senses too high water level for spin out and shuts down.
Oct 07, 2008 | Kenmore 43142 Front Load Washer
Drain problem
you can gain acess to the pump cleanout by removing 3 torx 15 screws from along bottom of front panel. justbehind the panel youl find the "bttoun trap. unscrew it and chances are youll find baby socks, bra underwires, etc... )somethings blocking the pump from orkin proerly, be warned scoop water out first, and tip unit back if possible. when oyu unscrew the pump clean out all water above will be coming out
Mar 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lost a underwire from a bra
Bra underwires are one of the main engines of the appliance repair buisness.
You do need to keep a close eye out for it in the filter but it probably will do no good to call for repair. The repairman most likely will check the filter and tell you to call back if you have any trouble. Until it works it's way down there isn't much you can do without disassembling the washer.(no small feat for some of them) The only real damage that may occur is if it pokes a hole in the drain hose between the tub and pump. This has happened, but rarely. They will usually make their way to the pump and you will hear the noise, at which time you can usually remove it with no trouble.
Be sure to wash bras in a delicates bag on delicate cycle in the future.
Hope this helps.
Nov 06, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal De
