Question about GE Profile JGP636 Gas Cooktop
Ignighters Clicking sound from the ignighters. Even when knobs are in the off position. Happened while cleaning the surface with mild 409. Think something got wet?
  • Anonymous Apr 15, 2009
    igniters are ignighting even when in OFF position. the contacts got wet
Problem came from excess liquid that contacted the wires. my fault
Posted on Apr 13, 2009
Have a gas cooktop that clicks even when the knobs in are in the off position
Good Afternoon Hon,
I understand that your Frigidaire gas cooktop, model# FGC30S4ASA, is clicking even when the knobs are in the off position. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and listen for the clicking with the burner knobs in the off position. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Cooktops
After cleaning the cooktop surface the "clicking"
I just solved the continuous sparking in my gas burner. I removed the control knobs and the rubber below those knobs. Gave the rubber and the area below it a good clean using kitchen and bath cleaning wipes that I bought from Coles. The key is to remove the water and grease from the rubber and the area below it. Good luck!
Mar 24, 2011 | GE Profile JGP636 Gas Cooktop
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
My ignition will not stop clicking
hi friend,
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
it sounds like it is the spark module that's making the clicking noise. normally there are 4-6 wires that connect to it , and if you are not comfortable making the repair yourself then I would call an appliance repair company.The part should cost 30-50 $ Good luck
hope this helps u
please rate me.......................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Ignighter issues
gud day,try to clean the area wer the knob place by using vaccium try to remove the knob then claen by vaccium,coz the dirt inside coz of grounding.
Jan 08, 2009 | GE 30 in. Profile JGP989 Gas Cooktop
Igniter clicking when all four knobs in off position after water spill
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
Oct 28, 2008 | GE 30 in. JGP336 Gas Cooktop
GE gas stove top igniters won't stop clicking
My wife just called me with the same problem - all 4 starters are clicking repeatedly - which started while the range was being cleaned.
From a Google search, this is what I found. Don't know if it will solve our issues, though wanted to share as it sounds like we may all be suffering from dirty starters (electrodes).
My surface burners keep "clicking" even after the burner is lit. There are a few things to check for.
And, to check the model number, look at the various places pointed to in the upper left of this diagram. http://www.applianceaid.com/newpics/range-model2.JPG
Oct 18, 2008 | GE Profile JGP636 Gas Cooktop
Clicks occur in "low" position instead of "lite" position
Sounds like the switch electric sending unit needs to be Ither cleaned and dry good or replced. It's not hard at all, They are located under the knob switches, you will have to remove the knobs and the top cover, they look like a small square box wit a hole in the middle with two wires on the sides, just unplug the wires and lift the box off the switch rod. cleane them and dry them good and put them back.......that should do it.....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 16, 2008 | Cooktops
GE Profile JGP636 Gas Cooktop Logo
376 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
