Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
My router is detecting the internet but i cant get the internet on my computer. I cant connect to my router but it says that im connected with limited access. I have it hooked up through the router with a cable right now. If I where to remove the cable from my computer I would get local access only instead of local and internet access. Ive hit reset ive reinstalled it ive done every thing short of taking it out back and beating it with a hammer.
  • Anonymous Apr 18, 2009
    when I hook up netgear to my PC and my son's lap top it dectects the internet but he can't connect nor can I. we've unplugged reset did everything and still nothing. And I'm not calling the 888-number and spending 20$ for the call. Can it be bugged or virused?
  • 854 Answers
Limited or no connectivity indicates that the computer cannot acquire a valid IP address. This is due to incorrect network key you have entered. We need to check the correct WEP key in your router's setup page. Here are the troubleshooting steps we recommend you try:
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Posted on Apr 12, 2009
Im trying to set up my router,i have been using it before but my cpu has been damaged by lightning,sinv\ce then i cant use my router. i followed instructions on how to re configure it,my laptop and pc...
sometimes this router are afected by the lightnings, verify that the internet connection is working well by plugin the internet(ethernet) cable directly to your computer, if it gets connected to the internet we are sure the probleme is isolated to the router.
The easiest way to check if the problem is the router WAN(internet) port would be connecting a known good router just for few minutes
Aug 29, 2011 | Linksys Wireless-G WRT54G Router
I cant connect my wireless n router to my internet connection
hey can you see your router pppoe connectied to you pc or laptop
Jul 05, 2009 | Computers & Internet
No wireless detect connection
Hi
Note all changes to be made from wired computer only . Any computer that is phisically connected to the router.
Open the router setup page by typing in your default gateway address( router address) on the web browser
You can get it by
Start -> run -> cmd -> ipconfig
You will see the router setup page opening up
Check what it says . IF on the top it says Internet Status :: Connected then
1. Under wireless you'll see channell and ssid
2. Change channell to 6 or 11 .That gives you the best wireless signal strength . This is the most probable cause .
If you want you can also change the
3. Check your security key
4. And apply changes
5. Now on your wireless laptop go to Control panel ->Network connections -> wireless network connections -> right click -> deleate preffered networks -> refresh netweork list
6. You will find your network there select and connect.
Works great
If Ip status : says not connected
1. restore factory default
2. reconfigure router
3. reconnect
This shoud help and please let me know .
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My laptop did not detect the D-link driver
I guess your trying to connect without a cable....
Try to connect to a KNOW good router.
Try connecting with a cable.
Try connecting with another computer to your router.
Let me know what you get.
Oct 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless router
First make sure wireless is turned ON or enabled on the computer, then use the View Available Networks to connect to the your SSID or network name. IF you can connect to router then you should be able to surf Internet.
Jun 26, 2008 | NetGear WGR614/WG511 (wgr614nawg511nakit)...
Wireless connection of netgear wireless router for compaq laptop
Sometimes firewalls on your computers can cause connection issues. I had the same problem with my home network. I had norton internet security 2008 on both systems, but the firewall settings on both computers had to be adjusted to allow the computers to talk. If you have different brand firewalls on each computer, you should consider to switching one of the computers so that it matches the other.
Another thing you want to do is log into the router's web utility and check to see if the wireless settings are blocking wireless connections in some way. You also want to make sure the ssid broadcast is enabled.
Finally, you really should consider using security on your router, so wireless connections would be password protected. I suggest wpa personal.
May 03, 2008 | NetGear WGR614 Wireless Router
Router connection
Hiya, either the seetings on the router fiewall have changed, or the shock has damaged the circuit board somehow, the speed that the computer says its connected to is whats called LOCAL only, meaning you are connected at that speed to the router only, circuit boards do funny things when shocked, have you tried another router? Id put my money on the board being fried.
Apr 08, 2008 | MSI Wireless-G RG54G3 Router
My WiFi problem
Please confirm the manufacturer and model for the router being used? The router in the heading of this message does not appear to have wireless capablity.
Secondly in terms of your sisters machine assuming it has an ethernet port have you tested it using the cable just to make sure there are no (software) firewall issues on her computer affecting access to access the internet.
Sorry I have no Nintendo DS knowledge specifically. I may try to research the issue after the router and laptop issues are resolved.
Are there any other wireless devices (computers) currently working correctly with your wireless router/access point?
Dec 15, 2007 | Belkin (F5D5231-4) Router
Can't Connect to Internet
there is a need to reconfigure your router to work with your modem. If configured already before, then there is great chance that this has been set back to factory default.
Oct 06, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
212 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
