Question about Mtd 22" Yard Machine Push Mower
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
WILL START AGAIN WHEN COLD
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Posted on Apr 17, 2009
Fuse gets hot and burns out
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
Electric Mower will not start, trips the breaker? - Instructables
www.instructables.com/.../Electric-Mower-will-not-start-trips...
Instructables
Dec 29, 2015 | Garden
96 honda civic engine ,starts & runs fine cold-but dies when warmed up
Did you find a fix?
Same problem, wondering how you fixed it?
Mar 07, 2012 | Cars & Trucks
I have a 1992 Honda prelude that when it starts up it idles at 1100rpms fine but after it runs for like five minutes it drops idle to 900rpms and as soon as I hit the gas it stalls out..... It starts right...
on a cold start car will idle fast till it warms up then will drop to about 1000 rpm, try increacing idle speed so when it warms and drops it should stay idleing
Feb 12, 2012 | 1992 Honda Prelude
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
Mower starts runs five minutes then turns off. After it cools down it will start again and will have same problem.
Hi, your problem sounds like a fuel delivery issue. Make sure that the carb is receiving enough fuel to the bowl and that the fuel filter is not clogged. Hope this helps.
Nov 16, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a 1988 mk 2 golf when i start the engine the heater warms up as normal but when the engine warms up the heater starts blowing cold air out. also now that the cold weather has started after driving...
sounds like the thermostat stickng as when engine gets cold the choke will start workin again, causing the over reving or your electric fan is on all the time "over cooling" the engine
Dec 22, 2009 | 1988 Volkswagen Golf
1998 Honda CRV stalls once it warms up then after
You need to replace your coil pack. It sounds to be over heating which results in no spark being sent and the enige dies. Very common fault and easily fixed.
Dec 17, 2009 | Honda CR-V Cars & Trucks
I have murray self propelled lawn mower. Last
Remove the air breather filter, it might be dirty. Stephen.
Sep 21, 2009 | Garden
Stalls when engne warms up
Your ECT (Engine Coolant Temp) sensor is bad. What's happening is at cold start it richens up the fuel mixture and as it warms up the ECM thinks it's still cold and essentially the "choke" is still on. Also check your coolant level. If you don't have enough coolant in you engine/radiator, the ECT doesn't know what to do so it thinks it's cold.
Jul 13, 2008 | 1990 Jeep Cherokee Limited
Mtd 22" Yard Machine Push Mower Logo
875 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
