Computers & Internet Logo
A
Anonymous Posted on Aug 31, 2013
PK5001Z WPS light is blinking red - Zyxel Computers & Internet
google mail
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 23, 2014
google mail
Contributor
Level 1:
Answers
Questions
0
Helped
679
Points
0
Due Centurylink's proprietary firmwarez not Actiontec's. Also I suspect they may be pushing firmware using UPnP.
3answers
Can you fix my pixma canon mg3500 printer?
Hi, you need to count the blinks to know what error is.
102 stc i can`t use the phone. light for the phone on router is red this happened after reseting the router
Did you change the password on the router? Did you WPS to connect the phone to the router? If so, use WPS again.. that's where you press the WPS button on the router and tell the phone to connect via WPS at about the same time.
What does WPS button stands for.
WPS=WiFi Protected Setup. This is typically used to connect a Wireless Router to a Wireless Repeater. Both must be WPS capable and using WPS is similar to pairing two Bluetooth devices. One device transmits WPS and another listens (after you initiate a WPS sync). You have to enter a WPS PIN and the devices should connect.
Why are both the Wireless and WPS lights on my modem\router always on solid green, when I only have a DSL connection?
The wireless and WPS lights solid green mean that the wifi and WPS are active. It also means that your home network is exposed to anyone with a laptop/pad/smart phone who knows how to hack into systems that have not been set up properly with the proper security.
I see the following security issues with your router:
1. The router's password is still the default or it does not have one.
(This means anyone who knows your router maker and model can easily break into your network and systems and steal your info, the router maker is broadcast by your wifi SSID, so they know it)
2. WPS is enabled and active (WifiProtectedSetup)(this service is a major security hole that is used by hackers to gain access to routers, it must be disabled for protection)
3. The wireless (wifi) connections are open (not encrypted), anyone can intercept the wireless traffic and read it. WPA2/AES encryption needs to be configured for the best protection.
4. The router's built in firewall may not be configured correctly exposing you to drive-by hacking.
To resolve these issues requires someone who understands router security and is best done onsite.
You need to engage someone you trust to check and configure your router and computer systems properly to protect yourself.
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Wps button
The front of your Actiontec modem has a button and light for Wi-Fi Protected Setup (WPS). If that button was pressed or the WPS process was started, that button may light up or blink.
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
There is a green light on on top and after i push the wps button a red light blinks for a while and then stays on any ideas the laptop that has been used with this router is not getting a connection now...
WPS means Wi-fi Protected Setup its a kind of wireless security for the router. There are two methods of activating it either by push button(Which you tried) and other is manual for that you can log into the Router setup page using "Http://192.168.2.1" in the Internet explorer and enter the pin code printed under the router. You should click on "Wi-fi protected setup" towards the left side of the page and leave the password field blank and click submit and enter the code and click on "Start" or Apply changes. The reason why it didnt work through the button is probably because your laptop might not be in range or switched off. It has a utility installed on your laptop which recognizes the connection and let it protect using WPS.
Hope it helps. Please feel free to contact us for further assistance or information.
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
