Question about Toshiba 32AFX61 32" TV
Screen shuts off
My screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on.
What year were the toshiba 32AFX61 manufactor?
Posted on Sep 11, 2011
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
My screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Posted on Sep 11, 2007
2 Suggested Answers
SOURCE:
  • 144 Answers
SOURCE: my screen will turn on right after unit is plugged
Unfortunately it has nothing to do with the power plug.
If you turn it on and it works normally but then shuts down it's activating an internal protection circuitry to prevent damage to your set. It's not an adjustment, it's not something you can fix at home. Sorry to be the bearer of bad news but it will likely require a shop repair.
Posted on Mar 31, 2010
Why is my Samsung ln-t1953h takes 5-10 minutes to power on. During boot the red light is blinking and clicking.
How old is the tv set also do you have it plugged up to a power cord? Can you tell me how many times does the light blink thank you.
Aug 19, 2014 | Samsung LN-T1953H 19 in. LCD HDTV
My new dual XDMA450 stereo wont turn on. when i take off the face plate the red sensor light is flashing. this only happens when my head lights are on. what problem am i having with my stereo and why
Check your wiring connections. A similar thing started happening to me out of the blue. The unit would work fine for a period of time, and then just shut off for no reason, and I couldn't get it to come back on. The next day, it would come on again when I started the car and stay on for a while, only to shut down again. The red light behind the face plate continually flashed, regardless of whether the receiver was working. In my case, there was something off in my red wire connection. The unit would turn on / shut off when I moving the wires on either side of the connection. I redid the connection, secured it with electrical tape, and the problem has not reoccurred. If the red wire is not the problem in your case, try the black and yellow connections. These appear to be the wires that could cause this to happen. I can't explain why the power kept repeating the power on / off cycle, unless the wires were in just the right position to be moved / jostled slightly while driving. Hope this helps.
Oct 19, 2012 | Dual Audio Players & Recorders
My lavazza espresso point capsule machine has stayed plugged in and working for almost 2 years. Now it turns itself off after being on a short time or after brewing a few shots of espresso. If I turn it...
The only possibilities I see here are either the Plug Holder with Fuse Block which sometimes goes bad and periodically will shut down the unit. The other possibility is that the Electronic Card has gone bad. It over-heats and shuts down power.
Jun 01, 2011 | Lavazza Espresso Point Capsule Machine
My screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. This could...
Mar 30, 2010 | Toshiba 32AFX61 32" TV
Touchscreen wont cut off when car is turned off.
It is normal for the screen to stay on for a short period of time after you turn off the engine and leave the car. It should shut off after a minute or so.
Feb 13, 2009 | 2006 Land Rover Range Rover
Toshiba 32AF43 problems
bright red with lines left to right? would be shorted crt. shutting off would be normal due to high beam current.
Nov 09, 2008 | Toshiba 32AF43 32" TV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Tv keeps turning off
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
Feb 05, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Television shuts down as if thermal problem, but cool
Shorted red driver trans shorted red pic tube defective focus/screen block any or all of these stk's on convergence module check the solder joints on convergence module
Jan 06, 2006 | Panasonic PT-40LC12 40" Rear Projection...
Toshiba 32AFX61 32" TV Logo
278 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
