Question about Samsung Computers & Internet
My monitor changed colors now is pink and blue, what to do?
  • 2,567 Answers
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector.
If this is not the case, there could be a loose connection on the monitor's PCB, or a failing component. This needs to be checked by a qualified technician.
Posted on Apr 12, 2009
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
The monitor color is pink...i want it to change to normal color...
Colors on the monitor are produced by mixing the three "primary" colours.
If the monitor is not producing one of those three colours, you can get "pink" instead of "white".
Fix the monitor, or replace the monitor, or replace the video-card (if using a different monitor also produces "pink").
Jun 21, 2011 | Computers & Internet
My monitor has been disconnected for a while during office remodel...now when i plug in it's very pink in color
Likely the cable is not connected properly, and the blue VGA signal isn't arriving. Try unplugging at both ends, and replugging it securely, screwing the connector retainers in.
Also, a redness of color may be due to the color management of the monitor, the so-called "color temperature", being changed from 9300 or 10000 K to 6500 K. Try checking the monitor color controls.
Nov 05, 2009 | Computers & Internet
Proview monitor PL926WSi Screen goes out after about 5 seconds
Hello Joe,
A red or pink coloration on the screen indicates bad backlight bulbs. They are just like standard fluorescent bulbs just much smaller. When they start failing they light up with a pink color and that will make the screen look pink or red. You can change them but it may not be worth the trouble. You can do a Google search for compact fluorescent tubes and check prices.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Oct 18, 2009 | Computers & Internet
The screen color is off. It looks yellow, pink
Try changing the connecting cable. You seem to be connecting it with a composite cable which might have loose pins.
Sep 15, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
The 3 colors wires that hook into my pc are yellow, red & blue, but the colors on the pc are: pink, white and blue is there a color match up?
I suspect you've got the audio and video cables mixed up.
Video inputs on monitor will be yellow for video and red/blue for audio. PC end of cable will be round and connect to your video card. Or .. you should have a cable with a 15 pin mini D on both ends or a DVB cable.
The pink, white and blue connectors on your pc are audio connections for speakers/headphones.
Google is your friend
The ... Google is your friend
Jul 07, 2009 | Acer AL1951Cs 17 inch LCD Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
69 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
