Question about RCA RTD160 System
Where is the tuner control - RCA RTD160 System
Universal Remote Code for Technics Tuner
The code will be found in a compatible universal remote control.
Dec 23, 2017 | Audio Players & Recorders
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
Is there a firmware upgrade for the 32dw6834 tv to improve digital signal reception?
this TV Tuner is analog Tuner, dont have any digital tuning, only control and process is digital, so not have any possibility a firmware for tuner, only for boards of control and process video/audio
Nov 22, 2009 | Philips Televison & Video
Sound only works with DVD
Tuner is lokely the cause or cable box that is hooked up is on mute.
If you have no cable box or sat system the cause would be a bad tuner at coaxe region there is ashort in the connection the brings the adio filtered from the tuner to the control IC AMp witch is part of the tuner assay what this means is bad tuner or bad control ic at coaxe region. Or its one of the causes above a device is on mute. Best of luck to you in your repairs. good feedback and ratings will be expected further in this diagnosis.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 22, 2009 | Televison & Video
URC-50 Uninversal Remote won't control a Dish VIP 612 DVR. Both Companies say one is RF and the other IR so they can't "talk" to each other. How can a person "get around this" without buying another...
I don't know about the 612 but the 722 I have has green tabbed control for IR control of output 1 and by default of tuner 1 and controls the OTA tuner and will work with many IR remotes if set to address 1--they don't send the address. The blue tabbed one is for RF-controlled output 2 and tuner 2. Setting it to single (vs. dual) mode allows either remote to control tuner 1 and swap to tuner 2 and do PIP. Unfortunately the 612 does not have this mode.I haven't had a combo remote work well with tuner 1 even. It is much better to use the Dish remote for most of the work, well only volume and power on the TV. There are a lot of buttons most combo remotes will not have control of. Hey, I have 2 VIP722 and the TV remotes on the chair arm.Check with menu-menu to see which address code and control mode is set. But if manual allows and you can pull tab after opening battery slide and change switch beneath, you may be able to use as IR remote in preparation for your combo, just to be sure controls sent correctly. (Hold Sat button until all light, press address 1, press # to set remote [lights go out], then press record to set receiver while you watch menu-menu. less than 10 sec per step.)-Ken
Jul 15, 2009 | Kenwood RC-R0720 Remote Control
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
FRONTECH TV TUNER MODL JIL-0606 CODE 10 DOESNOT START
How to configure Remote control in my TV tuner card Model No. JIL - 0606
Jun 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Power cord for a TS-50S and also a tuner control cable
Hi crowdisr,
your best bet is trade me, and have you tried the agents?
regards John
Apr 26, 2009 | Radio Communications
Programming a ATSC DTV tuner on a RCA Universal Remote
Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
Dec 27, 2008 | Televison & Video
Wireless headphones
you need a stand alone tv tuner with audio/video out
how to install:
1. connect tv antenna to tv tuner
2. connect tv tuner video out to tv
3. connect tv tuner audio out to your wireless headphone control tower.
Fixya... GOOD DAY!!!
Sep 14, 2008 | Computers & Internet
RCA RTD160 System Logo
21 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
