Question about Toshiba 32HL95 32 in. LCD TV/HD Combo
Wireless headphones are connected to the audio jacks, but will not work. When connected to the headphone jack will work, but TV audio is eliminated. What should I do?
3 Suggested Answers
  • 223 Answers
If you are electrically minded I cant think of another solution apart from to open the set and de-solder the socket from the board and then you might be able to gain better access to the stuck pin. Some of the sockets are open at the back enabling you to poke something through the gap so you might be one of the lucky ones. Please remember to take all necessary precautions while working on the tv especially the discharging of capacitors as a spark from one of those could do a lot of damage to the tv or yourself. If you open up the set and it looks too complicated please dont feel like you have failed just put it back together and find a competant technician. Good luck.
Posted on Oct 04, 2008
  • 11361 Answers
SOURCE: Is there any way to
You can try using the audio line out in the back, but you may need to use and adapter if the Sennheiser does not use RCA style for audio input. Post back what kind of audio input jacks the Sennheiser uses.
Posted on Jul 30, 2010
  • 11361 Answers
SOURCE: I just bought a Toshiba 32CV100U and i am trying
You may have to check the on screen HDMI audio setup, it may be set to get the digital audio through the HDMI cable instead of the picking up the analog audio through analog port.
Both source and receiver of the HDMI audio setting must be setup correctly.
Please check that.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jan 15, 2011
0 characters
1 Points
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
is it a wireless headphone or a wired one..??
genrally wired headphone use 3.5 mm audio jack ... try to find the 3.5 mm jack input on your tv and connect the headphone..
Sep 09, 2013 | Flat Panel Televisions
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Flat Panel Televisions
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack" are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Flat Panel Televisions
I want to connect wireless head phones with my Panasonic LCD TV (Model#: TH-L32X9D). There's no additional Headphone slot. So how can I use the wireless headphones. Also is there any way to switch TV...
Most TVs these days do not come with headphone out jacks. If your TV has RCA audio out, you can get a RCA to Headphone jack.
If your TV has no audio outputs at all, you're out of luck.
If your TV is equipped with audio out, there will be an option in the speaker or sound menu of your tv to turn off internal speakers and transmit directly to external speakers. If there is no audio out on your tv, this will not be an option.
Mar 11, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
The vizio e322vl headphone jack is not documented by Visio. There is an "Audio" spot next to "RGB PC" and I tried various jack sizes b none works. If you have a soulution, can you...
that audio jack is input only it is stereo jack to connect from the comptuer to the tv when using the RGB input. most headphone jacks if they are there would be on the side of flat panel tvs. otherwise the audio output may be digital(optical) or normal rca (red and white) that you can hookup to the headphone system.
Dec 23, 2010 | Vizio E322VL 32 in. LCD TV
I have new RCA model VHP141 Headphones but will not work with my new Vizio TV. Where do I plug them in the TV?
Visio might not have a headphone jacks at all! Look around your set and, probably you won't find jack marked as headphone. You might need to use wireless headphones, what have an rca plugs and connect them to audio monitor out on your tv set.
Alex's TV Service,
Philadelphia, PA 215-806-5980.
Jan 21, 2010 | Vizio VO47L 47 in. LCD TV
Want a TV wireless headphone with no headphone jack or audio out
You may have to connect the headset through a VCR or DVD player that does have the output connections.
Sep 05, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
My headphones wont work with my emerson lc320em9 tv jack on headphones is to large to fit into audio out jack ontv
i suppose you want to connect a 6.3mm jack (very big stereo headphones) to the 3.5mm connector on the tv ... google for >> 1/4" Stereo Jack to 1/8" Stereo Mini Jack Adapter
Jun 13, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Toshiba 32HL95 32 in. LCD TV/HD Combo Logo
Top Toshiba Flat Panel Televisions Experts
Are you a Toshiba Flat Panel Television Expert? Answer questions, earn points and help others
