Will not display a picture
The monitor was dimming a touch during the lat week. Last night it cycled on than off. Restarted and the same continued to happen. this morning there is no picture at all.
    Novelist:
  • 190 Answers
It would appear that some component has given out the ghost. The earlier symptoms were giving you warning that something was failing. If the monitor fails to display anything, even after increasing the brightness to the max, it's probable that it needs servicing, or replacing it altogether.
You don't specify how old your monitor is, nor whether it's a CRT or LCD, but in both cases, they're built to last several years, except for when they come with faulty components from manufacturing.
Posted on Aug 20, 2009
Why does my Sony Google TV NSX-46GT1 46 in. HDTV LCD TV powers up, displays application screen on bottom, makes a computer chime and shuts off completely, and starts the same process over and over aga
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 25, 2014 | Sony Google TV NSX-46GT1 46 in. HDTV LCD...
Verticle lines across my screen with no picture.
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
Ok i have a problem i bought a iphone from my friend last night so he restarted everything and its been on the same screen for the whole night last night i dont know what to do i tryed restarting and...
. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
when you see the silver Apple logo you can let go of the buttons.
and then try the phone and see if it is ok now
good luck
Jul 29, 2010 | Apple iPhone Smartphone
Sony generation 2 radio/cd works fine but the
no other alternative but to renew the display panel
Oct 06, 2009 | 2007 Ford Focus (3 Door) Hatchback
Monitor falls asleep during/after startup
control panel
click power settings
set the monitor to never sleep or dim
same on all windows.
the monitor is totally programmable
why not tell OS?
windows 10?
or google
why does my windows 10 monitor go to sleep
10,000,000 hits
endless.
the defaults under windows, are always wrong,
it's to keep the FEDs happy with there Energy Star bs.
im on laptop now far far from USA
set it all to not use sleep etccetra.
Feb 28, 2017 | HP Computers & Internet
Dark display
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 11, 2009 | Computers & Internet
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Mach speed
Unplug the the dsl & any other device except the keyboard & mouse. Double check the video cable at both ends monitor & PC. Boot up system. If the system starts shut down & connect 1 device. Boot the system. OK? continue to do this. On the dsl there is a reset button. With it unpluged from power use a pen & hold in the reset for about ten seconds. Reconnect the power & reconnect the Rj45 to the PC. Boot system.
Jan 26, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
