Question about Motorola XTN 2-Way Radio
I need to program
I have a total of 6 raidios but there all diferant ,how can i program them the same.
  • Motorola Master
  • 1,654 Answers
Here is a link to the CP100 user manual, it is the sister radio to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
Posted on Apr 13, 2009
My arieldoes not go down when raidio is turned of
It could be that the motor in your antenna has gotten disconnected or the plastic cable that winds the antenna up and down has broken. Typically, one simply replaces the antenna when it quits working.
May 22, 2015 | 2002 Mazda Tribute
I have a ford mondeo lx battery died so fully charged it and now car will not start at all it saying on the raidio vehicle id how do I get this id thanks
Try using a scanner to reset the ECM for the engine start problem ( immobiliser program corrupted). it may reset the radio but I suspect that you will need a radio code to get it to work.
Jan 24, 2015 | Ford Cars & Trucks
How do I get a grand total for just a department from a Royal 210dx cash register.
Are your departments set up properly?
This is how to check:
Running the Department Confirmation Report
You can print a report that shows the programmed information for a range of departments or for all departments. The range report is helpful if you want to see the programmed names of some of the departments, but do not need to see all the departments and other cash register programming.
You can also print a report that shows department information and sales.
For more information, see Running Management Reports on page 85.
Note:
Unless you specify a department range, all departments print in the
Department Range Report. This will take a few minutes.
To run a department confirmation report:
Programming > Department Set Up > Depart Conf Report
1 Press the Main menu (on) key.
2 Press the Arrow Down key to select Programming. Press the Amount Tend Total <Enter> key.
3 If you are prompted for a Manager Passcode, type the passcode number and then press the Check key. If you did not program a Manager Passcode, go to the next step.
4 Press the Arrow Down key to select Department Set up. Press the Amount Tend Total <Enter> key.
5 Press the Arrow Down key to select Depart C onf R eport. Press the Amount Tend Total <Enter> key.
6 Select how you want to see the report. If you select Display, use the arrow keys to review the report in the clerk screen.
https://www.royalsupplies.com/cashreg/1000ML_Instruction_Manual_eng.pdf
Jan 10, 2015 | Retail Supplies
The car wont start the bary is ok as the raidio
Your starter selenoid is bad replace the starter if its all one assembly
Jan 07, 2010 | 1988 Mazda 626 Turbo
Msi motherboards
Off course you cant, but your processor model, make and whether x64 or x86. Mac computers are suppossed to be totally diferent beacause the communication language(internal) is different from DOS based softwares that microdoft uses. You need an Apple PC to run mac OS....sodeep
Mar 22, 2009 | Intel Computers & Internet
Excel formula creation
= (a3) minus (b3) won't do it for you?
Sep 05, 2008 | Excel (SS8SATAS5128400R)
POSSIBLE TO convert 1973 ford F100 390 to inline 6
No not much trouble. However it depends on what Transmission you are using. If A stick, then you will need to change bell housing and you will need to use flywheel fro either a 302 V-8 or another strait 6. 300 or 240 which ever you are using will also need the hard mounts from another truck. The mounts are diferent from one with a 6 to one with a V8. Also the radiator if I remimber correctly is diferent in the way the hoses hook up. There will be a little more money to do this change. But it is easy once you make the plan and see what needs to be done. I have gone from a 300 6 to a 302 V8 in a 78 F-150. It was quite easy and i did it in a day. Any more questions ask.
Jun 18, 2008 | 1981 Ford F 100
I have voices that come thru while I am on line at diferent times and diferent voices. I have tried to get rid of them by removing cookies and some programs. I also have about four programs installed for...
Reformat your hard drive. Sounds like you have too many programs installed to protect your computer. One of these computers may be some sort of spyware.
You only need one good antivirus software program with a firewall. You must subscribe to them every year in order to continue to get virus updates.
May 11, 2008 | Computers & Internet
Motorola XTN 2-Way Radio Logo
309 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
