Question about Epson Stylus Photo R200 InkJet Printer
Label paper will no longer feed
I print labels with my Epson Stylus Photo R200. Recently, none of my paper will feed. It all jams. Any suggestions?
  • joan1112 Apr 12, 2009
    Hi tigertail. I tried cleaning the little rollers, then attempted a nozzle check. The paper either goes through with no printing on the check, or won't feed. I'm SO frustrated! Joan
  • 163 Answers
Most likely some of the gum (or even part of a label) has stuck to the inside of the paper feed mech. It all depends on where it is. You could try giving the inside of the feed hopper a good scrub with alcohol wipes or similar, reaching in with your fingers or using a wooden stick. I have successfully used this method on this same issue several times in the past.
Posted on Apr 12, 2009
My 1290 fails to feed the paper. It seems that most of the time the paper is picked up at one edge so the paper crumples
When you experience damage to the paper when feeding it means that it is hitting something in it's path. Open the printer and check the path of the paper for any foreign objects like torn paper, staples,and the like. And if you have printed any labels, part of the label maybe caught on one of the rollers.
May 18, 2010 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Jan 30, 2010 | Epson STYLUS R350 Photo Printer
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Printing labels on DVDs
Go to the software website which you are using. You might be able to find it there.
May 26, 2009 | Epson Stylus Photo R200 InkJet Printer
How do i print labels using epson r2400 photo printer?
If you are using the Avery template, make sure you change the page setup settings from Manual Front (default) to Default Tray (sheet). Then when it tries to fix the layout, select ignore (on Wrd 2007 anyway). Then select Photo / Glossy paper and hopefully away you go.
Mar 31, 2009 | Epson Stylus Photo R2400 InkJet Printer
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Printer will not print
Firstky u need to make sure that the printer drivers are nt corrupted, i wuld suggest u reinstall them, make sure u do nt have any paper jam, check 4 small paper pieces inside, listen if the printer tries to pull the paper in.
Feb 22, 2008 | Epson Stylus Photo R260 InkJet Printer
Epson r200
turn off and disconnect from computer.
load plain paper.
press and hold paper feed button WHILE turning the printer on.
still no ink on the paper with new genuine cartridge ?
contact manufacturer for repair.
Dec 17, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
209 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
